Hi good people I am sure some of you have seen my car it was recently on eBay
It had all the listed faults and many more I work at longbridge and have set about
the saving of a great car I have re fitted most of the interior trim no fixings or clips holding most of it together. The boost isue was the boost mod valve the Speedo is still broken yet to fix. The electrics were all over the place replaced fuse box working on getting gearbox reconed. I need to fix sunroof it will tilt but not slide it seems like it only drives on the left hand side any ideas?. The engine mounts are shot I think knocking are they still available. It's a great car and look forward to my ownership and getting to know some other 800 fans cheers Ian.
820 turbo coupe
- Joined: Sun Feb 22, 2015 6:30 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: 820 turbo coupe
Hi Ian welcome and good luck with your project.
In order for members to help each other out a few details will help on advice being sought. Model, year, engine size, man/auto etc also if you include chassis and reg no Dollysprint may provide you with some build history.
Pics of you car are always nice to see as ther are a few that go through ebay
Re: 820 turbo coupe
Hi its a 820 turbo vitesse reg R852XNT will post pics asap cheers.
Re: 820 turbo coupe
