Heater Blower fan resistor
- Location: Rochester area [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi
Im looking for a Denso fan resistor 077200-3840 as mine has failed, please get in touch if you have one to sell or can point me in the direction of one.
Rimmers nil stock & unable to supply and none on eBay at moment,
- rovercoup
Re: Heater Blower fan resistor
Mogtypus was selling one on ebay recently and did not sell so presumably will still have it awaiting relist at some point. Maybe worth a cold call email via ebay.
Is it for a Mk1 or Mk2, air-con or non air-con?
I might have a working one in my shed attached to a rather dead fan unit.
Hi
Thanks for the advice, got one from eBay, fitted and still no go!!!,
I was convinced that was the problem,
Back to 820 Heater fan pages from czar12 and others on the forum, some great reading and advice.
- traineefarmer
Have you checked the bi-metal overload switch?
The fan motor itself might be dead, have you tried feeding the motor directly?
Tom, glad to hear that my posts on the 820 heater fan were useful to you. From memory, the two wire wound resistances were good so I bypassed the beryllium metal bit on the fan plate with a 121c temperature resistant fuse. That is to say, if the temperature rises above 121c, the fuse will blow. I now think that 121c is a bit too high so a 100c fuse should work just as well and not blow.
It was very useful to have all the fan speeds working last winter.
- traineefarmer
I had one fail from corrosion on my first 800 16 years ago. My solution was a bit less refined than yours though. A short length of copper wire got soldered over the top!zcar12 wrote:Tom, glad to hear that my posts on the 820 heater fan were useful to you. From memory, the two wire wound resistances were good so I bypassed the beryllium metal bit on the fan plate with a 121c temperature resistant fuse. That is to say, if the temperature rises above 121c, the fuse will blow. I now think that 121c is a bit too high so a 100c fuse should work just as well and not blow.
Saw out my ownership of the car....
Hooligan!
Bi metal fuse, replaced, fan will run on high speed when resistor linked out, and when removed from car.
Might try a lighted match under the dash!!!
That points to the switch then for the intermediate speeds.
Hi all
Thanks for all for your advice in sorting this problem out, it was an earth fault, ( by wiper motor) collected a few spares so will be ready to fix quickly next time.
Looking forward to laying on my back with my fingers in places they shouldn't go
Pat.
Pat.
Ooo-errr missus!
Glad you got it sorted Pat!
Users browsing this forum: No registered users and 14 guests
