Grey floor mats (Mk2)
- Alex SBY
As the title really. I'm after a set of carpet mats in grey for a mk2. Not fussed if they are not new and / or need a clean.
These are NLA from Rimmers now. Anyone got a set lurking in their spares pile they'd not mind selling?
One or two 800s...
Re: Grey floor mats (Mk2)
I don't have a set, but I bought some from a manufacturer on eBay a few years ago, but they didn't fit my car. So I sent them back with card board cut-outs of the original mats and they were made just the same. I think for the set it was £23.00. They look oe spec.
Is it early boot release and fuel flap switch on the floor or later model with boot & fuel on centre consule... ??
Had major trouble years ago trying to get the set from Main Dealer with the cut out one in the drivers mat for my `93 model sterling
You can still buy new BEIGE floor mats, but not grey.
- Lord Sterling
Alex - I'll see if I've got some. Most of my mats though are a Greenish tint. I know the Grey ones are amazingly hard to come by. I might have some darker Grey ones from a mk2 Vitesse.
- Alex SBY
Darker ones would be absolutely fine! Whatever will be better than nothing! Thanks Mo.
One or two 800s...
I suppose if you’re desperate you could do an old wheeler dealer trick and spray paint some beige carpets with grey aerosol paint? Just a thought.
what about trying some good quality dye? or are they treated to stop staining?Charles827si wrote:I suppose if you’re desperate you could do an old wheeler dealer trick and spray paint some beige carpets with grey aerosol paint? Just a thought.
What an idearovercoup wrote:what about trying some good quality dye? or are they treated to stop staining?Charles827si wrote:I suppose if you’re desperate you could do an old wheeler dealer trick and spray paint some beige carpets with grey aerosol paint? Just a thought.
Have seen these on ebay Alex they might suit your need if you cant find OEM onesAlex SBY wrote:As the title really. I'm after a set of carpet mats in grey for a mk2. Not fussed if they are not new and / or need a clean.
http://www.ebay.co.uk/itm/261242756079? ... 1423.l2649
Have you tried... Rimmers ?
Or these people..
http://www.mgroverpartfinder.com/page2/ ... chCount=70
Or these people..
Rimmers have these..
http://www.rimmerbros.co.uk/Item--i-EAH102670LOY
Marked as Left Hand Drive !!!
Very CHEAP though
Very CHEAP though
- Alex SBY
Cheers chaps. I reckon those LHD ones are worth a go tbh at that price!
One or two 800s...
- Alex SBY
Just to close this; I bought the LHD ones off Rimmers and they fit fine. Whilst the one that is for the LHD passenger (which goes on the drivers side) is long it doesn't obstruct anything so I've found (in an auto anyway). On a manual it might be different though.
Well worth £12!
Well worth £12!
One or two 800s...
