827 ignitor
- Joined: Mon Aug 09, 2010 5:44 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
827 ignitor
hi has anyone got a ignitor 827? cheap please.west midlands walsall.wv132hx.or post.cheers
Re: 827 ignitor
There's one on ebay Antuk for sale with the Main Relay. As the seller rightly points out, these are the only 2 things on an 827 (aside from catastrophic cam belt or water pump failure) that can stop it dead. Even when the HT leads go (i've had 2 sets die completely!) they will still start and run, albeit like a bag of spanners.
http://www.ebay.co.uk/itm/291221303066? ... 1423.l2649
If you can't stretch to buying both items in one go, send the seller a message, he may be willing to split them as this is the second time he's listed both of them together. He's a reasonable bloke and doesn't sell rubbish.
Re: 827 ignitor
ok thanks and cheers for that.been a bit busy sorry took a while to get back to you.
Re: 827 ignitor
No worries, did you get sorted?
Also are you sure the igniter is at fault? Are there any other symptoms besides non-starting? For example central locking not operating or anything?
- Tenesmus
Re: 827 ignitor
Think he got one from Brad in the end.
Pete
