Hi everyone,
This pipe is missing from my car and I hope that replacing it will reduce some of the intake roar.
Shown on rimmers as part no. 11
Does anyone have one they would sell to me?
If there are none available, could you give me some information as to how it is routed so I can make one from flexi pipe.
Many thanks in advance.
Fresh air to filter box pipe - Turbo
Re: Fresh air to filter box pipe - Turbo
item 11 which is the cold air intake passes down behind the passenger headlamp and just pokes through a hole in the inner wing area pointing towards the floor behind the front bumper beam.
The hose itself is quite a large bore pipe and quite stiff to manipulate down and round. I would think that one of these would be easily found at a breakers yard.
