'99 Coupe n/s door black finisher bottom of door
- Robert
- Location: Hamilton, South Lanarkshire [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Probably no chance but mine flew off on the motorway last week and can't seem to find any online so had to try here on the off chance
Thanks
Thanks
'99 vitesse coupe Charleston Green , ‘03 MG ZTT 190+ Anthracite
Re: '99 Coupe n/s door black finisher bottom of door
Crikey, is this the big long section you are talking about Robert? That is unfortunate, they are bolted on. I might know someone who can help, I will send a message and get back to you.Robert wrote:Probably no chance but mine flew off on the motorway last week and can't seem to find any online so had to try here on the off chance
Thanks
- Robert
About 4" high by 48" long looks like it was held on by sticky pads on plastic clips along the bottom of the door
That is the one from the lower door, they should have bolts at each end to help hold it in place. I have sent a message to someone breaking a coupe on the Facebook page.Robert wrote:About 4" high by 48" long looks like it was held on by sticky pads on plastic clips along the bottom of the door
- Robert
Thanks Simon
He is going to look over the weekend, so will let you know when I hear something.Robert wrote:Thanks Simon
quite right, they are bolted at both ends, but the bolts only go into the glued on clips on the back of the strip.
mine came completely loose and flapping around recently I had to remove it and re-glue all the clips back on.
good as gold now though
- Joined: Sun Oct 12, 2008 10:17 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Simon, did you have any luck obtaining this lower door cladding? I very recently lost my O/S one without warning on the A45 at speed (and yes, I've have gone back looking for it!)...
Ant
Ant
I am not sure if Robert got sorted out with the trim but I did not hear anything back I am afraid.
Sorry, Simon, I was rushing and got names mixed up!
I shall keep looking. I thought I'd bought a full set of coupe cladding from R800 NUT Chris a few years ago "just in case", but they're nowhere to be found. Anyway, it's an important engineering lesson about the long-term reliability of adhesives...
Ah, no, I meant CHR15E, but in searching to check the spelling of his username I see he sold the plate quite a few years ago. How time flies...
It went with my last R reg 827, I left it too late to transfer it off.
So DVLA will have the plate now.
- Location: NORWICH [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
if you are still looking for the cladding/finishers,i have a full set maybe 2 full sets.07737 833123
