Non airbag grey dashboard
- soundrediscover
I never liked the beige interior so have been swapping it out for grey
all that is left to do is the dashboard.
(I do have the airbag type in grey but would prefer the original style with shelf if at all possible)
Rock On!
Ian
Ian
- soundrediscover
Re: Non airbag grey dashboard
which is why I am after the non airbag dash......mrpcpc wrote:I don't suppose the airbag module will notice that the passenger airbag is missing.
Also, it's a modification. Not meaning to put a damper on things but it should be disclosed to the insurance company of any modifications.
The dash fixings are different on the side brackets for airbag and non airbag so make sure you gat those also.
The centre console is riveted to the airbag dash and is part of it. So you will also need the centre console for the non airbag type.
Rock On!
Ian
Ian
Hate to ask, but I assume you haven't skipped the beige/ cream interior?
(1997 820Si / LPG)
(1997 820Si / LPG)
And errm, how good is the beige non airbag dash? I could do with one for mine.
If you fancy having the Flint grey mk1 dash in the Shitesse I'll do you a deal.
You can have it for free!
IF!
You come around and swap it out yourself - as long as I have a dash of some description in the Shittese I don't care
IF!
- soundrediscover
Not yetDickie524 wrote:Hate to ask, but I assume you haven't skipped the beige/ cream interior?
Rock On!
Ian
Ian
- soundrediscover
slight lift so not too bad...., I will put you down as 2nd refusal as Dave Houston has been promised first dibs...MG Mal wrote:And errm, how good is the beige non airbag dash? I could do with one for mine.
Rock On!
Ian
Ian
- soundrediscover
Where are you?Alucard7002 wrote:If you fancy having the Flint grey mk1 dash in the Shitesse I'll do you a deal.
IF!
I have a spare with airbag that could be exchanged....
Rock On!
Ian
Ian
Cambridgesoundrediscover wrote:Where are you?Alucard7002 wrote:If you fancy having the Flint grey mk1 dash in the Shitesse I'll do you a deal.
IF!
2 minutes off the a14 at J32
It is a MK1 item in Flint grey not the Mk2 grey in case you were not aware.
Cheers
I got the wrong end of the stick Ian - i thought the beige dash was also non-airbag so won't be much help to me if it has an airbag sadly.
However, if you swap your dash with Dusan, perhaps we can sort out the carpets at the same time - he's about half hour away from me (2 hours in bad traffic! ) so you could kill multiple feathered freaks with one missile!
Aye, A14 is just a gorgeous road isn't it?scoobyh123 wrote:he's about half hour away from me (2 hours in bad traffic! )
I can supply access to tools, tea and coffee - however I may not be available for extra pair of hands. Let me know as soon as you can RE: dates and I'll let you know
- soundrediscover
It is non airbagscoobyh123 wrote:I got the wrong end of the stick Ian - i thought the beige dash was also non-airbag so won't be much help to me if it has an airbag sadly.
And yes that is almost a plan....
Rock On!
Ian
Ian
- soundrediscover
Grey is grey in my bookAlucard7002 wrote:Cambridgesoundrediscover wrote:Where are you?Alucard7002 wrote:If you fancy having the Flint grey mk1 dash in the Shitesse I'll do you a deal.
IF!
Cheers
I will have a look at possible dates and have a think.
Ideally I would prefer to take away the dash for later fitting rather than trying to do all in one go which may scupper Dave's hopes and dreams for a single session.....
Rock On!
Ian
Ian
- soundrediscover
Never did get this sorted......
Still on the lookout if any helpers?
Rock On!
Ian
Ian
I could still be on the lookout for a beige non-airbag dash but i know Dusan has scrapped Shitesse - whether he kept the dash i have no idea though.
The other problem for me is i need it to be coupé non-airbag dash as it seems from research i've done they are different to the others.
