As per the title,
Needs to be posted to New Zealand.
We have not been able to find anyone with the Microcheck/Fastcheck SRS module reset gear over here, and the SRS light is on. Caused by person trying to start car with flat battery, from what we can ascertain.
I am assuming a good replacement module will cure the problem.
Can anyone assist me please?
Graeme
Wanted....a SRS module for a '95 Sterling 2.7
- rovering
- Location: Hamilton, New Zealand [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
2003 Rover 75 Tourer 2.5 ltr Connoisseur
2001 Rover 75 Club SE 2.5 ltr
1995 Rover Sterling 2.7 (SOLD)
1990 Rover Vitesse 2.7 (SOLD)
1988 Rover Sterling 2.5 (SOLD)
1986 Rover SD1 Vanden Plas
- rovering
Re: Wanted....a SRS module for a '95 Sterling 2.7
Hiya Paul,
Thanks for your reply, no I am not that person! Haha.
I have since spoken to the mechanics I use, and he has told me that anyone with a good diagnostic machine should still be able to fix the car. Apparently they come with the older cables needed for pre OBD2 type cars.
As to how true this is, I will soon find out.
I have relayed the info I got yo my friend, and he has located someone who reckons they can sort it. I am eagerly waiting on the response from him.
Watch this space.
Graeme
Watch this space.
Graeme
- Joined: Fri Dec 30, 2011 8:49 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
If u need a module i think oi have one from a 99 rover 800 let me know the part number on yours and i can check if mine is the same. Regards mark
You may well be right hence why i need to check his unit number but they are a pain to get to.
- rovering
Thanks for the offer, but from what I have read, your one will be the later self reset one. I unfortunately need the earlier non resetting type.3pinplug wrote:If u need a module i think oi have one from a 99 rover 800 let me know the part number on yours and i can check if mine is the same. Regards mark
I have not got the ECU out, so am not sure of its specific number.
I will keep you in mind though, if and when I get that far.
Many thanks,
Graeme
