Coupé window regulator (motor) wanted...
- scoubix16
- Joined: Fri Mar 20, 2015 7:09 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Folks,
I'm after CUR10027 (LH window regulator) for my coupé so I can cure the calibration issue I have for one-shot up/down.
I understand that the RH one (CUR10026) can also be used as both regulators are identical, only the parts around it are specific...
I'm looking for a BRAND NEW one, as I don't want to mess around with a used one.
THanks for your help
'93 Rover 827 Coupé - LHD
'99 Rover 75 2.5 V6 Connoisseur - Dealer Launch - LHD
'04 MG ZT-T 260 SE (V8) - Ex-Longbridge 75 V8 Tourer development car - LHD
Re: Coupé window regulator (motor) wanted...
These people may be able to help and you could possibly even drive there and collect it. No idea on distance so if that's not viable then i apologise but you might get it a bit quicker than from Rimmers.
http://allbrit.de/UNI.cfm?PAGE=659947&SPRACHE=EN
You can change languages if you want on the site too, i know there's German and English, not sure what else though.
- scoubix16
Thanks Dave, I've never ordered (yet) from allbrit.de, though I've ordered from many XPart dealers in the past...
Will give them a try.
Cheers
Nicolas
Cheers
Nicolas
You're welcome Nicolas, i'm guessing yours is left hand drive so they're more likely to have the left hand drive drivers window regulator than someone like Rimmers. Good luck with it!
- scoubix16
Well the regulators are the same for LHD and RHD, meaning that a driver side becomes passenger side and vice-versa, but otherwise identical.scoobyh123 wrote:You're welcome Nicolas, i'm guessing yours is left hand drive so they're more likely to have the left hand drive drivers window regulator than someone like Rimmers. Good luck with it!
Unfortunately, both are no longer available with allbrit
I have a quote from another Xpart dealer for a RH one, but it's prohibitive (over 250 euros)...
Sorry - what i said and what i meant were two different things! What i meant was that as the left window is the drivers window on left hand drive, there's a better chance they would have it than the UK based suppliers as the drivers wondow gets the most use.
- Location: NORWICH [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I have got coupe right and left window mechs,doors,wings, boot lid, side trims, rear side windows,front windows i am in Norwich so not miles away,had them for my coupe which has gone now
you can or text me on 07737 833123
disco wrote:I have got coupe right and left window mechs,doors,wings, boot lid, side trims, rear side windows,front windows i am in Norwich so not miles away,had them for my coupe which has gone now
I might be interested - what colour are the body panels?
Doors nitefirered, petrol blue, dark blue ,I have 3 pairs
Boot nitefire red
Wings petrol blue
all of later coupes p reg onwards
I have also got foglights headlamps some abs sensors window switches, cladding ,window motors, side glass front and rear
Boot nitefire red
Wings petrol blue
also rear lights smoked type, door cards, window lift ecu's
