pumps gone on my coupe washer bottle so looking for a replacement. if the pump can be fitted just one of those, otherwise the whole Washer bottle (the one with the long neck) with working pump.
EDIT: No Longer required - I used a Range Rover P38 Washer Pump - was an exact fit.
Coupe Washer Bottle/ pump
- tonewheeldude
Last edited by tonewheeldude on Thu Oct 04, 2018 9:07 pm, edited 2 times in total.
Re: Coupe Washer Bottle/ pump
In stock at rimmers
http://www.rimmerbros.co.uk/Item--i-GRID004615
- tonewheeldude
Thanks Steve, arent those pumps for the rear washer or are they the same for coupe front?
Should be the same pimps Darren but double check as to which you've got as the fastback has two different plugs for the washer pumps so the front and back don't get mixed up.
