As above mine has a dodgy drivers window switch.
Please has anyone got one they are willing to sell? Mine has the four electric windows and it's grey in colour.
Thanks in advance Thomas
drivers window switch pack urgently needed
- Location: Plymouth, Devon [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
i want lots of british cars got 1 want more
- traineefarmer
Re: drivers window switch pack urgently needed
Scooby Dave is your man for this one.
I haven't got round to sorting through them yet Tom, Adrian has first dibs on a good 4 way switchpack as per the original agreement but after that there should be a few there.
As usual, life has got in the way of living!
Thomas, why not have a go at your door switch yourself? It may be a dry joint in the solder that is causing the switch not to work. I had the same problem and re soldered every joint on the circuit board. Even the LED's now work. Or if you are not good at soldering, find a mate to do it for you. Has to be worth a try.
Thanks everybody. To be honest I'm rubbish at doing things like this and I'll muck it up.
I also spend all week away from home so the few hours I do finally get I'd rather just be driving it.
Sorry if that sounds sarcastic it's not my intention.
Thanks if you could let me know about one that would be brilliant thanks Thomas
- soundrediscover
That's a shame I was down your way last week but hadn't seen this request - I have a box load which I think were displayed in a previous thread and could have brought them to you for testing.....
I'll have a look to see what is there - there may be one that has been marked as 'tested' that I can send.
Rock On!
Ian
Ian
Thanks id really appreciate it thanks Thomassoundrediscover wrote:That's a shame I was down your way last week but hadn't seen this request - I have a box load which I think were displayed in a previous thread and could have brought them to you for testing.....
Users browsing this forum: Google [Bot] and 3 guests
