ABS sensors
Caxton820coupe
Newbie
ABS sensors
Post by Caxton820coupe » Sat Mar 18, 2017 4:56 pm
Does anyone know where to get ABS sensors from..?
1997 820 coupe
1999 820 coupe
1994 Montego Countryman 2.0i
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
Re: ABS sensors
Post by scoobyh123 » Sat Mar 18, 2017 7:06 pm
Front or back ones Dick?
http://www.ebay.co.uk/itm/371033272993? ... EBIDX%3AIT
Those are the front ones, something odd about the left/right thing on them so you'd need to speak to Ron at Best of British (the seller) but also if you phone up rather than buying over ebay, you can probably negotiate a discount for buying a pair. :wink: :wink:
I had to drill, burn and grind the old ones out of the brackets on mine, i then sanded the hole a smidge oversize and mirror polished it and packed Vaseline round the outside of the sensor to prevent further corrosion of the bracket which is the main cause of failure as the aluminium oxide crystals grow and crush it! :shock:
The back ones are the same as Volvo 7/9xx front ones or indeed Mk3 Cavalier (and possibly others) but obviously they use different plugs so you may have to cut'n'shut a plug if buying a sensor for one of those. :wink: :D
Caxton820coupe
Newbie
Re: ABS sensors
Post by Caxton820coupe » Tue Mar 21, 2017 2:25 pm
Thanks, Dave!
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
Re: ABS sensors
Post by scoobyh123 » Tue Mar 21, 2017 6:32 pm
You're welcome Dick! :wink: :D
Did you get sorted? :? :?:
Caxton820coupe
Newbie
Re: ABS sensors
Post by Caxton820coupe » Wed Mar 22, 2017 2:52 pm
Not yet, Dave, but Ron is very helpful, and a good source of spares...are you going to the 1st April meet? And on 2nd April, there is a show at Old Warden...
Best wishes,
Dick
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
Re: ABS sensors
Post by scoobyh123 » Wed Mar 22, 2017 7:42 pm
Caxton820coupe wrote:..are you going to the 1st April meet?
At the British Queen you mean Dick? That's certainly the plan at the moment, hopefully in the Sterling with the other confusing set of wheels! :shock: :lol:
Caxton820coupe wrote: and on 2nd April, there is a show at Old Warden...
Best wishes,
Dick
Where is Old Warden? Haven't heard anything about a show there? :?
Caxton820coupe
Newbie
Re: ABS sensors
Post by Caxton820coupe » Sat Mar 25, 2017 5:23 pm
Yes, Shepreth, or wherever it is ...:-)
Old Warden, the Shuttleworth Collection, near Ickwell, Beds. google it and you'll see...
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
Re: ABS sensors
Post by scoobyh123 » Sat Mar 25, 2017 6:43 pm
That's the one!
Could only find an Easter Sunday meet online for the Shuttleworth collection/Old Warden, am i missing something obvious?
Caxton820coupe
Newbie
Re: ABS sensors
Post by Caxton820coupe » Wed Mar 29, 2017 12:53 pm
type in Old Warden car show, and click on the first result, and you should get the right information...:-)
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
Re: ABS sensors
Post by scoobyh123 » Wed Mar 29, 2017 5:36 pm
The first (non-sponsored) result i got was this Dick :
http://www.shuttleworth.org/events/classicrally/
Is that the one?
I had about 6-10 results before that, all sponsored by some search engine or commercial interest! :roll:
