Heater Blower fan resistor
patrover
Newbie
Post by patrover » Mon Apr 24, 2017 12:45 pm
Hi
Im looking for a Denso fan resistor 077200-3840 as mine has failed, please get in touch if you have one to sell or can point me in the direction of one.
Rimmers nil stock & unable to supply and none on eBay at moment,
rovercoup
Re: Heater Blower fan resistor
Post by rovercoup » Mon Apr 24, 2017 4:54 pm
Mogtypus was selling one on ebay recently and did not sell so presumably will still have it awaiting relist at some point. Maybe worth a cold call email via ebay.
Post by scoobyh123 » Wed Apr 26, 2017 3:34 pm
Is it for a Mk1 or Mk2, air-con or non air-con?
I might have a working one in my shed attached to a rather dead fan unit.
patrover
Newbie
Post by patrover » Mon May 01, 2017 7:09 am
Hi
Thanks for the advice, got one from eBay, fitted and still no go!!!,
I was convinced that was the problem,
Back to 820 Heater fan pages from czar12 and others on the forum, some great reading and advice.
traineefarmer
Post by traineefarmer » Mon May 01, 2017 7:33 am
Have you checked the bi-metal overload switch?
Post by scoobyh123 » Mon May 01, 2017 9:32 am
The fan motor itself might be dead, have you tried feeding the motor directly?
zcar12
Post by zcar12 » Mon May 01, 2017 9:40 am
Tom, glad to hear that my posts on the 820 heater fan were useful to you. From memory, the two wire wound resistances were good so I bypassed the beryllium metal bit on the fan plate with a 121c temperature resistant fuse. That is to say, if the temperature rises above 121c, the fuse will blow. I now think that 121c is a bit too high so a 100c fuse should work just as well and not blow.
It was very useful to have all the fan speeds working last winter.
traineefarmer
Post by traineefarmer » Mon May 01, 2017 9:22 pm
zcar12 wrote:Tom, glad to hear that my posts on the 820 heater fan were useful to you. From memory, the two wire wound resistances were good so I bypassed the beryllium metal bit on the fan plate with a 121c temperature resistant fuse. That is to say, if the temperature rises above 121c, the fuse will blow. I now think that 121c is a bit too high so a 100c fuse should work just as well and not blow.
I had one fail from corrosion on my first 800 16 years ago. My solution was a bit less refined than yours though. A short length of copper wire got soldered over the top!
Saw out my ownership of the car....
Post by scoobyh123 » Mon May 01, 2017 10:33 pm
Hooligan! :lol:
patrover
Newbie
Post by patrover » Tue May 02, 2017 9:09 pm
Bi metal fuse, replaced, fan will run on high speed when resistor linked out, and when removed from car.
Might try a lighted match under the dash!!!
Post by scoobyh123 » Tue May 02, 2017 10:34 pm
That points to the switch then for the intermediate speeds.
patrover
Newbie
Post by patrover » Wed May 31, 2017 5:42 pm
Hi all
Thanks for all for your advice in sorting this problem out, it was an earth fault, ( by wiper motor) collected a few spares so will be ready to fix quickly next time.
Looking forward to laying on my back with my fingers in places they shouldn't go :roll: :roll:
Pat.
Post by scoobyh123 » Wed May 31, 2017 9:47 pm
Ooo-errr missus! :shock: :lol:
Glad you got it sorted Pat! :wink: :D
