Windscreen trim
- Location: North London [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Windscreen trim
Hello,
I have 2 chip on my Windscreen. Apparently I can get a new screen but the retaining clips and trim are no longer available.
Have been advised that the clips may break when removing the old screen.
Does anyone know what I can do?
Is there an alternative?
Would it look odd or cause a problem if the surround is not there? I understand the window is bonded so should be secure without clips.
Or does anyone have any spare clips and trim?
Mk2 1995 version.
Thanks
Eric
Mk2 1995 version.
Thanks
Eric
Eric
Re: Windscreen trim
I just had the screen replaced in my 1993 827
Trim was removed and replaced without problem.
Worst case senario is that the clips may break , but it should be fine .
Re: Windscreen trim
Thanks deano but what happens if the clips do break? Does that mean the end for my car because they are structurally important? I am not really sure what the clips do.
Eric
- mjc9967
Re: Windscreen trim
AFAIK the clips are just for securing the trim? Nothing to do with the integrity of the screen itself.
Would just look a bit rough, I'd have thought (if the trim couldn't be refitted), might be able to get away with just one or two going south?
Standing by to be corrected, as always!
Re: Windscreen trim
I assume you mean these clips Eric?
https://www.rimmerbros.co.uk/Item--i-DCC10012
They're in stock at Rimmers where according to their listing, 8 are needed per car. You could pre-empt the whole thing and order 8 to be on the safe side, then it won't be a problem if the all break. Chances are most will break, after all they will all be old and brittle by now.
They also have the boot latch cover available for order in 2-3 days for a mind-blowing 17p so you could annihilate two flying feathered things with one missile, so to speak.
https://www.rimmerbros.co.uk/Item--i-FQW10009LOY
Hope that is useful for you!
Re: Windscreen trim
You're welcome.
- mjc9967
Re: Windscreen trim
That would solve it!
Do you know those clips are same for mk1 and mk2?
Re: Windscreen trim
I'm fairly sure the Mk1 and Mk2 used the same screen Mark (maybe with cosmetic differences) and the upper part of the car was more or less unchanged on the Mk2 "facelift" so there's a good chance they are the same. Maybe someone with a copy of the EPC will be able to confirm that, Rimmers only seem to go back to the early Mk2
- mjc9967
Re: Windscreen trim
Yep, definitely the same screen, just black edging and vin card cut out for the mk2
- soundrediscover
Re: Windscreen trim
Good stuff, a question answered before being asked.... My windscreen is OK but the top trim ropey for which I have a replacement ready to go....
Rock On!
Ian
Ian
Re: Windscreen trim
They are indeed the same part for mk1 & 2 DCC10012/13 8 required for the top of screen and 10 for sides front windscreen.mjc9967 wrote:That would solve it!
Rear windscreen is DCE10038 7 required for top and 10 for sides.
and as Dave has already linked, available from rimmers
