Wanted 820 clutch slave cylinder
Re: Wanted 820 clutch slave cylinder
Almost - it seems he's doing the owning and you're doing the maintaining!
EDIT - By the way, i pointed Dusan in your direction as he's after a brake servo, was thinking blue 820 seeing as it's surrendering it's clutch slave for the greater good (<everyone together> "The Greater Good") it won't be going anywhere so the servo isn't quite so vital.
True that ( great film btw)
2x Mk1 827 Vitesse Fastbacks
3x 825 Coupe
Mk1 827 Sterling Saloon
825 Sterling Saloon
825 Sterling Fastback
820 Vitesse Coupe
820 O Series Mk1 Fastback.
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
All fixed
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
Great news! How bad was the radiator in the end?
Not too bad, it actually took longer to cobble together a pressure test rig than it did to fix it. (Cycle inner tube cut in half over each outlet)scoobyh123 wrote:Great news! How bad was the radiator in the end?
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
Nice idea! Worth investing in a tube just for the purposes of testing! What size was the tube (e.g. 20 x 2.125" or what?) so i can have a look round to see what's about. Got a few things i need to pressure test in the (hopefully) near future and like that idea.xpuffin wrote:Not too bad, it actually took longer to cobble together a pressure test rig than it did to fix it. (Cycle inner tube cut in half over each outlet)scoobyh123 wrote:Great news! How bad was the radiator in the end?
Took it off my mountain bike and the tyres are quite chunky, I'll have a look later.scoobyh123 wrote:Nice idea! Worth investing in a tube just for the purposes of testing! What size was the tube (e.g. 20 x 2.125" or what?) so i can have a look round to see what's about. Got a few things i need to pressure test in the (hopefully) near future and like that idea.xpuffin wrote:Not too bad, it actually took longer to cobble together a pressure test rig than it did to fix it. (Cycle inner tube cut in half over each outlet)scoobyh123 wrote:Great news! How bad was the radiator in the end?
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
3x 825 Coupe
825 Sterling Saloon
820 Vitesse Coupe
