wanted 820/825 kv6 auto radiator
Hi rover fans anybody got a coolant radiator for a rover 825 kv6 auto or 820 same rad, in good leak free condition cheap, had some quotes £105 aluminium new, £76 steel new, and £110 Second hand, none of these I can afford, I live in weston super mare, need to sort the leak out soon only minor at the mo but soon be doing a round trip to leicester this month I want to be sure I can make it there and back in a day with no issue's many thanks.
Regards Tony
Regards Tony
Hi iam Tony, I currently have seven 800's a 1996 827 sterling, a 1996 820 vitesse turbo, a 1989 827 vitesse manual which needs a part/full resto, 1999 KV6 sterling,1998 KV6 sterling, 1998 vitesse turbo,1991 H Reg 827 vitesse Auto all fastbacks.
Re: wanted 820/825 kv6 auto radiator
Does yours have the thermoswitches in the right hand end tank Tony? Also does it have the ATF coolers/heat exchangers in the end tanks?
Hi Dave no the thermostat switch is in the V of the engine on a kv6 next to the sealed thermostat, also the kv6 auto is not like the honda auto, the honda auto rad has the gearbox oil cooler built in to the rad, also the honda auto with aircon has the thermostat switches X2 fitted in to the rad non aircon has one, where as the kv6 auto has separate oil cooler mounted on the gearbox behind the radiator, so in other words apart from the hole's at the top and bottom of the rad for the fitting of the fans, all you have is the top hose fitting and bottom hose fitting that's it. cheers Tony
In that case it's as i thought Tony - a manual rad from a late 820/825 will do the job for you seeing as there is a separate ATF cooler and no thermoswitches in the rad.
I might have one but i'll need to check over the weekend.
Hi Dave thankyou fingers crossed them, not wanting to take the preverbial what sort of ready's are you looking for and can you post adding the cost to what you want for the rad, as I don't have alot of money as I live on disability, I did ask Theresa may for a pay rise but she hasn't got back to me yet LOL, so yeah have a nice weekend Dave take care.
Regards Tony
Regards Tony
Sorry Tony, it turns out i've already sold it some time back, the other one i might be able to lay my hands on wouldn't be suitable as it has the holes for the thermo switches in the right hand end tank.
Are you sure it is the radiator that's leaking and not a hose that's perished in the end or something silly? There's a few rads on ebay for 825s but they're all diesel ones and the hoses fit in different places so again, not suitable for yours.
Hi Dave not to worry but thanks for looking, i thought it was the pipe but looking at the rad it's seen better days it looks really old it's quite rusty at the bottom, i will have to keep an eye out for a used one or save up for a new one. Regards Tony
The other alternative would be a radiator repair service near you. They may well be able to recore your existing rad cheaper than new/reconditioned or even just repair it.
I have never yet come across a radiator repairer who can recore for less than the cost of a new one.
Small soldered repairs no problem, but recores? No chance!
If you have other 800s, can you not steal the rad off one of those until you can afford to replace it with a new one?
- gibbzy2k1
- Location: nr Cearphilly, South Wales [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I believe I have one left. I will have a look this evening and get back to you.
"Hey, let's be careful out there"
Callen
1994 Rover 820 Vitesse Sport *RIP
2005 MG ZS+ 115
1997 Rover 825 Sterling Coupe
1998 Rover 825 Sterling Saloon
Callen
2005 MG ZS+ 115
Thankyou Callen speak to you later this evening then.
Regards Tony
Regards Tony
- gibbzy2k1
Sorry I didn't get back to you last night Tony. The lock on the garage is seized solid... So I got another job for the weekend
Callen
2005 MG ZS+ 115
Callen
2005 MG ZS+ 115
- soundrediscover
I may have the one from my old KV6 stashed in the garage.... can't guarantee it remains leak free after 8 years storage although it was OK when put away.
FOC if of interest, but I will have to check I still have it (LE16)
Rock On!
Ian
Ian
A generous offer Ian and a twinge of irony - i think Tony needs the radiator for a trip to Leicester and unless i'm mistaken, LE16 is a Leicester postcode?
Users browsing this forum: No registered users and 24 guests
