Centre dash piece
- Lord Sterling
Centre dash piece
I would like a centre dash peice as found in Early Mk2's as I dont like the later Mk2 ones with horrid clock, I was thinking about changing the clock for a digital one made out of a modern digital clock/watch:
Failing that, I'll most probably want somthing like the one below, or maybe an earlier one from the Mk1's:
Failing even that, I'll probably just leave it as it is....
Anyone else have any other ideas?
Thanks,
Lord Sterling
Thanks,
Lord Sterling
Fitting a newer style of clock sounds like a good idea. Be different at least.
I'm not keen on the digi ones of lower spec cars personally. The wood and the analogue clock just look better IMO.
- Vard66
There was a Mk2 digital clock?richard moss wrote:I think I've got a mk2 digital clock - but not the dimmer/hazard switch panel.
I also have the full mk1 setup available if required.
Have you any pictures of this, Richard?
Vard.
2004 Astra SXi 1.7 CDTi
1995 Land Rover Discovery 3.9 V8i
______________________________________________________________________
