Hi, my Coupe is in deperate need of new filler pipes, the whole thing has fallen away ! I also need a CV joint to make it drivable. Does anyone have these parts?
There are some other bits I want but that will ahve to wait, without these two its a very big paper weight!
Stewart
Needed fuel filler pipes and CV joint
- Location: Wantage/Chippenham [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
1999 Rover 75 2.5 V6 Connesieur
1997 Citroen XM TCT VSX
1994 Citroen XM TCT Exclusive 5 speed, 1 of 2
1992 Range Rover Vouge SE 3.9 auto LPG
1985 VW Golf GTI
1975 MG Midget
1959 Austin Healey Sprite Mk1 (1380)
1985 VW Golf GTI
1975 MG Midget
Only just thought about it. I have a filler on a MK1 outside. That any good?
I'll need to get it off and double check it's ok naturally.
Mk1 is fine! only differance I think is the restriction to stop you putting leaded in the car.. oh and deisel!. But as mine is a pre augst '92 car it I may be lookingd of the non cat exhaust from a Mk1 for it as well, but thats not so important!
Setwart
Setwart
1985 VW Golf GTI
1975 MG Midget
1985 VW Golf GTI
1975 MG Midget
It's not the tidiest one I've ever seen but it's solid. I rubbed the crusty bits off and it all seems ok. No issues inside. Needs a clean and a paint I'd say.
Exellent.. PM me and we will sort it out! I will get it shot blasted and power coated, hopfully it will last longer than the original!
Stewart
Stewart
1985 VW Golf GTI
1975 MG Midget
1985 VW Golf GTI
1975 MG Midget
Users browsing this forum: No registered users and 22 guests
