I am looking for a petrol filler pipe for a T reg 800 Sterling.
The one I have is leaving a pool of petrol after the car has been filled.
As it is only at this time the fuel appears I guess it must be near the top as there is never any fuel around after the filling.
KV6 Nc
Hi - Fuel filler pipe wanted
- Location: Solent [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Blessed are the cracked, 'cos they let in the light.
Hi Chris
I think so but I have lost it, not only the thread either I might add.!
- Location: Chatham Innit [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I think any pipe (certainly from the petrol powered cars) will do you.
When you put it on Nutcase (can I call you that )...I would take the time to clean up the pipe and inner arch and thoroughly rustproof/waxoyl everything. Those pipes run just close enough to the inner arch to be a right trap for muck and suchlike...
Malcolm
Malcolm
Range Rover 4.6 HSE
Rover Vitesse Fastback - RIP
Rover Vitesse Sport - RIP
Rover 827 Vitesse - RIP
Rover 216 Vitesse - RIP
Re: Hi Chris
http://www.rover800.info/forum/viewtopi ... ight=#8153KV6Nutcase wrote:I think so but I have lost it, not only the thread either I might add.!
Re: Hi Chris
Happens to us all.KV6Nutcase wrote:I think so but I have lost it, not only the thread either I might add.!
