1998 Diesel belt tensioner
- JulianO'Connor
- Location: Norfolk [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Yes I'm in need of one now as the old one is making embarrassing noises - if any of you old derv owners have one kicking around still I'd be most grateful if you dug it out. And pay you of course.
aka The Serpent
1972 MG B GT
2004 Subaru Legacy Tourer
2008 Subaru Justy R
1972 MG B GT
2008 Subaru Justy R
I don't anymore, sorry.
To be certain, which one are you talking about?
It was the main pulley on mine that failed.
- JulianO'Connor
The one that's just behind the power steering pump, it points downward pushing on the belt from above.
Don't know if you recall but when you got the pug, you looked into the Rover's bay and noticed the tensioner was installed at a cranked angle instead of vertical and asked if it gave any bother. Well I'm pretty sure it is now!
aka The Serpent
1972 MG B GT
2008 Subaru Justy R
1972 MG B GT
2008 Subaru Justy R
Ah, the damper wasn't it. Yep I do remember now. It should be in a line.
The bracket that pushes down on can wear as well. Mine did, it has a copper sleeve and allows it to rock.
- JulianO'Connor
Well I read that keeping the damper compressed is the issue with installing them properly, so as mine is not compressed I should be able to get it out for a look without much of a risk.
My local Rover place is confident that they can get one but they don't know when - potentially a few weeks, may be more and I'm not sure how long mine will last. The other thing I was thinking of was seeing if the similar bits off Cherokees or Scorpios might do.
aka The Serpent
1972 MG B GT
2008 Subaru Justy R
1972 MG B GT
2008 Subaru Justy R
I've seen the damper replaced by a home made, manually adjusted bracket before. It was on a car owned by Pete Harrison from the 800 Yahoo group - the damper had broken and he created a replacement out of a few bits of steel plate a dn a few bolts.
He's since sold the car (to Malcolm Harvey, I think) so if you ask there, he may be able to send a piccie or two. It looked quite tidy and did the job nicely - and Pete said it was easy to set up.
- JulianO'Connor
I think the Rover chappy said the pulley wheel was easier to get than the whole unit. That and a bracket would be good, I'm not after automatic adjustment - the way mine is installed it isn't doing that anyway!
Thanks chaps, good advice as always, especially about the Yahoo group possibility.
aka The Serpent
1972 MG B GT
2008 Subaru Justy R
1972 MG B GT
2008 Subaru Justy R
