Drivers door handle for a Mk1
- Location: North Herts [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
As above, anyone got a spare Mk1 drivers door handle assembly.....preferably in Nordic blue!
'91 827 SLi Fastback - back on the road at last.
'89 Sterling - work in progress.....
'99 Sterling - on loan
- Very Tall Brad
Re: Drivers door handle for a Mk1
This reminds me, I have a load of door handles in the garage, but I don't know which are which (mk1/mk2), any chance you can take a quick picture of one brad?
As my traumatic experience at the weekend taught me....they look very similar but the Mk2 version has a fixed black seal around it and plastic hinge pins, only after fitting it did I find out that the keying for the lock barrel is reversed
- BlueRover
Very Tall Brad wrote:Yes, but not Nordic.
Brad
Oooh, I could do with one for the turbo, the handle is fine as is the key barrel but the surround has cracked allowing play in the lock mechanism. It's quite secure but I am going to sort out the alarm switch ( intermittent unless fettled with) and I think a stable lock platform would help somewhat.
I have a tin of spray paint so colour isn't important. I do have a new Mk2 handle which I was going to attempt to use but as said before, the lock surround is ridged and has no grommet visible.
So if no Nordic Blue is available what's the best match? Atlantic blue or black at a guess....what colours you got people?
Spare me from the trauma of a Nightfire Red Mk2 door handle
- Very Tall Brad
I shall have a look today and see what I have got. They are easily painted, though.Jango wrote:So if no Nordic Blue is available what's the best match? Atlantic blue or black at a guess....what colours you got people?
No longer an 800 owner!
- mjc9967
Yes as Brad says easily painted with a rattle can from Halfords... be a shame not to. I would suggest any other blue colour as a base, although a good finish over any colour should be easily achievable.
Nordic Blue eh? Have we seen pics of this car?
- whitelion58
- Location: Shropshire [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I did a piece on door handles here:
http://www.rover800.info/forum/viewtopi ... =12&t=4829
My conclusion was that Mk1 handles are flat around the lock barrel hole, Mk2 have a raised lip. Also, as mentioned above, the cutouts for the lock on the inside face the opposite direction
'86 825 Sterling Saloon
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
If it ain't broke, fix it till it is.
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
Not yet, the shame of a red door handle you know.....or that could be my excuse until I figure out how to post pics here!
- mjc9967
Go we need to see this. Been ages since I had a bit of Nordic to ogle at... (the colour, chaps, the colour!) send em to me and I'll post them if you like! Especially in 827 f/back guise.
- Very Tall Brad
Mark The Nordic Explorer...did you ever follow up that late Mark 1 827SLi f/back in Nordic that was on Gumtree in August?
Brad The Door Handler
- mjc9967
Brad, you are funny.
I knew that would bring that up again.... much thinking but little (actually, no) action. Much as it tugs at the heart strings you know I have difficulty keeping two cars in my plans at the mo, let alone three
By the way, I believe it WAS grey, after all, but still extremely attractive, nevertheless! My bad, as they say in linguistically encoded American sitcoms
- Very Tall Brad
Don't you get worrying over that one already. Laters
