Well my car went to scrappy due to camshaft seizing and then a block crack. So I want to help you to keep your wonderful R17's in good driving condition.
FHR10010ANV - Analog clock
KKU104740 - Engine bracket plate (timing cover)
LBH100130 - KV6 Engine upper cover
LBH101120 - Rear timing pulleys X 2 SOLD
LDF106080 - Full cylinder head X 2
LDR102530 - Front head plastic cover with ROVER word
LDR102960 - Front head cover with oil filler
LGC106110 - Inlet camshaft (suitable for front and rear head)
LGC106120 - Exhaust camshaft (just for front head due to CPS plastic ring)
LHB101110 - Front timing pulley x 1
LHB101630 - Timing belt tensioner (the one hold by hydraulic tensioner)
LHC100260 - Front and rear timing pulley hub X 3 2 OF THEM SOLD
LHG100400 - Auxiliary belt main gear - Damper
LHH100500 - Crankshaft gear timing belt drive
LHP100610 - Timing belt tensioner (hydraulic)
LJJ100401 - Timing backplate assy. lower rear
LJR102941 - Timing backplate assy. upper rear
LKB107110 - Inlet manifold assy. Right one
LKB107120 - Inlet manifold assy. Left one
LKC101610 - Front exhaust manifold
LQC000040 - Black oil cap
LQN100650 - Oil dipstick tube
LYP101080 - Screw and washer - Rear timing pulleys to camshafts X 2
********* - Full plenum, inlet manifold with VIS, MAP, etc
MAP100930 - Fuel regulator vacuum pipe
MHB101640 - Throttle body with cruise control system
MHK100600 - Manifold absolute pressure sensor (MAP)
MHN100130 - Injector clips X 12
MJN100610 - Fuel rail with both underbonet fuel pipes X 2
MJY100390 - Injectors X 18 (6 of them are almost new, half moth of use)
MKC103991 - ECU 825 KV6 Sterling Automatic AirConditioned S.N. 255960
NAD100730 - Engine starter (KV6 automatic)
NEC10047EVA - Coil pack (+1 new extra coil, 4 coils in total)
NGC102800EVA - Spark plug wires (Coils to spark plugs)
PCF10035 - Coolant expansion tank X 2
PCH112260EVA - Coolant hose, thermostat to rail and heater unit
PCH112270EVA - Coolant upper hose, engine to radiator
PCH112290 EVA - Coolant hose, ATF cooler to thermostat
PCH112630EVA - Coolant pipe, T piece (including this) to expansion tank
PEH100920EVA - Coolant hose, manifolds to T piece
PEM101050 - Coolant thermostat X 1
PEP101970 - Coolant pipe assy. Pump to thermostat
PEP103270 - Coolant pipe assy. Block out
PGF100730 - Fan, radiator / AC condenser LH
PGG100740 - Fan, radiator / AC condenser RH SOLD =)
PHB101870 - Air cleaner full system
PQG100142 - PoliV tensioner
PQR100780 - PoliV belt idler pulley
PQR101110 - Power assisted steering pump pulley
PQS101210EVA - PoliV belt X 2
PQU100170 - PoliV belt idler pulley bracket, on timing plate
QFX100140 - Power assisted steering DOT reservoir
QVB100850 - Power assisted steering pump
SCB100140 - Cruise control electronic control
SCB100150 - Cruise control main relay
SCC100030 - Cruise control vacuum actuator
SCH100080 - Cruise control vacuum actuator to throttle body hose
SRB100530 - ABS hydraulics modulator
TGD100650 - Automatic gearbox Jatco JF403E with torque convertor
TGG100060 - Automatic gearbox Jatco JF403E dipstick
TPB100120 - Drive plate KV6 Automatic
WAM4243 - Crankshaft bolt with washer
YLE101800 - Alternator
YLU101350 - Alternator bracket mounting
YSB106380 - Engine full wire set SOLD
YUD100630SMJ - Beige window and mirror driver switch pack SOLD =)
YUD100650SMJ - Beige window passenger switch pack SOLD =)
I think it is all, but ask me if you need anything, I could have forgotten some parts like relays, wires, switches, coolant hoses and pipes, PAS pipes... I have also green carpets, air ducts... Fans relay as well.
I like thinking of my parts being used by Rover enthusiasts!
I have to add:
I found my CD with PDF's, manuals, workshop...
1998 825 KV6 parts for sale
Re: 1998 825 KV6 parts for sale
I'm interested in these parts, how much, where and when, etc,etc.
Regards
Ian
Regards
Ian
- Lord Sterling
Ramiro, the seller of these parts, is located in Spain so postage will need to be factored in. Y'all.
- claudio
- Joined: Fri May 11, 2012 6:55 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
hello do you have the seat memory HHF100060?
cheers,claudio
cheers,claudio
825kv6 wrote:Well my car went to scrappy due to camshaft seizing and then a block crack. So I want to help you to keep your wonderful R17's in good driving condition.
I have to add:
Thanks for that bit of information, I thought Coventry was in the West Midlands, doh!Lord Sterling wrote:Ramiro, the seller of these parts, is located in Spain so postage will need to be factored in. Y'all.
- Location: Valladolid, Spain and Coventry (WM) [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
haha yes, Coventry is in West Mids as soon as I remember..... But I do live in Spain, however I used to spend summers in there.
