1999 825 Si In White Gold BREAKING FOR SPARES.
- Location: Letchworth Garden City [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: 1999 825 Si In White Gold BREAKING FOR SPARES.
Are you local ? Its just that Im not sure I will have much, if any, spare time this side of next year. But you are welcome to come down and see chap
2002 Trophy Blue Ztt 190
2004 S-Type Sport
2004 S-Type Sport
The top of the shock goes through the top mounts Paul. The shock helps keep the rear wheel upright. The spring is between the body shell and the lower wishbones and the lower wishbones bolt onto the rear trailing arm at the "rear" end of the trailing arm and to the chassis with their other end.
Hope that gives you an idea what the back end is like.
Jim - i have a pair if Paul can't help. They're in reasonably good serviceable condition too, else i wouldn't have saved them.
- 820Vitesse
Dave that would be great if they are already removed would save a lot of work to for Paul or myself.
Hope you dont mind Paul, thanks for your replies.
Don't mind at all chap
2004 S-Type Sport
2004 S-Type Sport
Saves us both some spanner time then Paul!
- Captain Sensible
- Joined: Tue Jan 13, 2015 10:51 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hiya,
What kind of condition are the front indicators in? And what is the wood trim in the coin tray like? I also need a driver's side window switchpack if available...
As far as I remember the indicators are good......the wood is ok.....but the switch pack has gone.Captain Sensible wrote:Hiya,
2004 S-Type Sport
2004 S-Type Sport
- Captain Sensible
Fantastic! If the indicators are nice and clear and have their little rubber strips (I've lost mine ) and the coin tray is scratch free I'd be very interested. What sort of money would you be after for them?
Sam - which bit are you calling the coin tray? Would it be the bit on the end of the centre console as shown here? It's only just in the pic (one of my old pics, not from the car in question)Captain Sensible wrote:Fantastic! If the indicators are nice and clear and have their little rubber strips (I've lost mine ) and the coin tray is scratch free I'd be very interested. What sort of money would you be after for them?
I think the confusion has arisen because there was a coin tray fitted up to about 96/97 when it was replaced by a headlamp adjuster switch to meet with EU regs and can be seen to the right of the steering wheel in this shot - it even has "COINS" written on it but they never had wood on them.
FYI i happen to know Pauls car has the headlamp adjuster switch in place of the "official" coin tray so i hope it's the centre console bit you're after!
- Captain Sensible
Yes, the bit under the handbrake, that's the one (non-official coin tray?). Mine has the headlight adjuster as well.
Glad that's cleared up then!
PM sent to you chap with pics of indicators and wood bit.Captain Sensible wrote:Yes, the bit under the handbrake, that's the one (non-official coin tray?). Mine has the headlight adjuster as well.
2004 S-Type Sport
2004 S-Type Sport
- Captain Sensible
Everything has arrived A OK. Nice one! Cheers
- Joined: Sat Oct 24, 2015 11:25 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
How much for the front drivers side abs sensor chap ?
Thanks
Thanks
