Breaking 1996 825 Coupe.... :(
Re: Breaking 1996 825 Coupe.... :(
I know for a fact the scuttle is gone from this coupe. You're correct though, coupe scuttles are unique and not quite as wide as saloon/fastback scuttles.
- Charles827si
Deano, I'm not sure if you sent the radiator expansion tank I bought from you on ebay. Or perhaps I had it deleiverd to the postoffice. Can you confirm that this was posted please? Thanks, Charles
I didn't realise you did buy one of them.... message it back thru ebay so I can trace which item it was , have sold a couple of them recently and several scuttles.
need to sell off all good spares to raise some much needed funds .
Also , I have been meaning to reply to your question about the left over coupe shell , just never got round to it. sorry
I`m not ready to let it go yet , but even when I do... you do realise it has a dent in the off side rear wing and all the arches have a fair bit of rust on then.
If required I`ll put some pics up
- Charles827si
Cheers for your honest reply Deano. If and when you feel ready to part with the leftovers of your coupe, I would like to view the external and internal body panels and parts left on the car before we can hopefully arrange a deal.
I will message you through ebay re, the 800 expansion tank. Thanks again - C
