Breaking 1996 825 Coupe.... :(
I need to dispose of my Coupe in the next couple of weeks, I don't have much time or storage space .
so I`m gonna sell a few bits on ebay to the highest bidder, need to get some cashback,
window switchpack, cd+stereo, expansion tank, door mirrors, Ecu+fobs etc
Can anyone else suggest some other things worth keeping... maybe items that are only found on a coupe, such as the aeriel (worth keeping I thought) or any other bits of trim...
Any members need anything in particular ?
as I said I don't have much time and space, my boss wants it shifted out of the works yard
Its green(Not BRG), kinda dark Forrest green metallic colour , Brad did once tell me the colour but I`ve forgotten it
It has beige leather(slightly darker then my other sterlings though) + green carpets.
The car does still run , but the headgasket has gone
Re: Breaking 1996 825 Coupe.... :(
Where are you located? Just thinking about collection/delivery of the bigger stuff.
Dean, that's gutting - no parts needed for me, but I've heard it's nigh on impossible to get rear screens for the coupe so if you can manage to extract that, could be worth a bob or two.
Is it possibly Woodcote green?
Hi Dean
Bonnet alarm switch, fuel regulator, throttle regulator, floor mats, jatco box, windows lift ecu, fuel flap release solenoid, boot release solenoid.
Regards
Ian
Regards
Ian
yes I think it maybe woodcote green...
I`m in southwest London .
I`m not really doing the big stuff as I haven`t got much room for storage,
and I don't wanna lose all the skin off me knuckles trying to remove bits no one wants....
unless, of course, you wanna come and unbolt it and take it away
Hi deano
My list won't take up much room, all easy to get at, no skin loss.
Regards
Ian
Regards
Ian
Hi Dean,
i'm interested in the carpets and maybe one or two other bits. The scuttle panel is apparently unique to the coupe although i'm not sure why.
As for bits that are worth saving, the ECU, CCU, alarm reciever module under the centre console and the fob are always useful - the ECU and CCU are matched together and the alarm reciever and fob are matched too. Ian (Stanker) might be interested in those last two bits!
Someone mentioned the rear screen, also the rear side windows, doors, door glass etc and anything electrical - relays, fuseboxes, ABS sensors, ABS modulator/ECU, copy valve, front & rear shocks/springs and other suspension bits that wear (upper wishbone assemblies for example), fuel filler neck and tank, fuel pump, rear lights, boot lid - the list goes on!
Depends how much room/time you've got to remove the bits and store them unless you have a buyer for the bits as they come off.
Will send a PM shortly about the carpets
You have a PM Tom - just a brainstorm!traineefarmer wrote:Where are you located? Just thinking about collection/delivery of the bigger stuff.
- Joined: Tue Jun 26, 2012 6:33 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Deano, Dean here !
i need a radiator front grille cover........is that available ?
let me know please and your address/contact details
cheers
cheers
Deano - sent you a PM a few days ago about the carpets, have you had a chance to read/reply yet?
Deano - if you want - I will buy whatever is left of your coupe - including the shell. Just give me a price, time, date and location with postcode to collect the car. Or is it too late now?
Thanks,
Charles
Thanks,
Charles
Most of it has gone mate , all that's left is the shell, body panels and engine(and that aint complete)
and I`m down Sarf in London
What in particular is it your after ?
Hi Deano, I'm in luck then! It's the shell and body panels I require - the rear body panel sections of the car. Thanks
It will be easier for you, if I collect the whole car. Also I can pick out anything else I need.
You haven't checked your email I sent on Monday to you here Deano. Are you still interested in coming to a deal over your coupe?
Probably a bit late on this but yes the scuttle panel and wing mirrors are unique to coupes due to the windscreen being a steeper rake than that on the saloon/fastback.
