Was trawling the bay when this appeared in my suggestions. I had to post it when I saw what new sensor it needed! I bet it smells nice though when fixed. Absolute class! Take a look and you'll see whey Ive just PMSL!!
http://www.ebay.co.uk/itm/Jaguar-x-type ... 1921868270
Jaguar needing new sensor
Re: Jaguar needing new sensor
thats a cracker, my sensor on the rover is a pot pourri mixture.
fleet now includes
- Joined: Fri Nov 02, 2012 8:26 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
After seeing this:-
I've used glade on my relays
I've cleaned the lamda sonds with shake and vac
I've replaced my crank angle sensor with Mr sheen metalic
ABS sensors are now cillit bang
SRS sensors are now green cross code controlled
Unfortunately, my cigarette lighter somehow causes St. Elmo's fire
Sounds like the cigarette lighter on my old 827 SLi - didn't know some numpty had wired it up the wrong way round until i plugged my 12V impact wench into it. Not a bog-standard forward/backward jobby (although it is now!) but an electronically-torque-controlled animal that you set the torque on a digital display then it winds the fastener up to that torque and stops.sid3400_0 wrote: Unfortunately, my cigarette lighter somehow causes St. Elmo's fire
The smell of frying chips (of the silicone variety) isn't very appetising but is generally expensive!
