2.0 coupe rear suspension
- Location: Cambridge [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Morning !
Having whacked a kerb on the n/s/r (only myself to blame..) I now need rear suspension parts as the wheel is now tucked under...if anyone has any appropriate parts, I would be very happy !
Thanks,
Dick
Thanks,
Dick
1997 820 coupe
1999 820 coupe
1994 Montego Countryman 2.0i
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
Re: 2.0 coupe rear suspension
Check these guys out, they are reasonable with price and will remove parts and post to you unless you can get there to do it yourself.
Old school breakers yard turn up with spanners and tools.
http://www.ebay.co.uk/itm/1997-Rover-80 ... SwnHZYcUEg
What parts do you need Dick? I've probably got the bits you need sitting around and i'm a bit closer than the one Steve kindly linked to.Caxton820coupe wrote:Morning !
Thanks,
Dick
Thanks, Dave, I'm not entirely sure which part is bent, or broken, and I am off to my local garage tomorrow morning to try and find out on the wheel-free lift. I think that I will need the hub, damper and lower arm....and if I can get those bits, get the O/S as well..
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
You may only have knocked the alignment out Dick and it could be adjusted back in to spec, depends how much of a wallop you gave it though! The adjusters have a habit of seizing in the rear arms though and usually need coaxing with WD40 or similar and an impact wrench to get moving again before the can be adjusted.
Won't be able to help with the dampers though, i don't have any good ones left.
See what the diagnosis brings tomorrow and go from there though!
Hi,Dave, thanks for that.
We got the old girl up in the air this morning,and it seems I have hit front and rear N/S wheels, and the guy at the garage tells me that, not only do I need both N/S hub assemblies, but the engine subframe is a bit bent, too...however, he reckons that with some heat, and the application of brute force, he can put that bit right! So now the search begins for both damper units
Dick
Dick
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
I think i have those hubs Dick, which bits of the hubs have you damaged?
What on earth did you hit and at what speed?????
As for the rear shocks :
http://www.ebay.co.uk/itm/KYB-Shock-Abs ... SwrXdXKz7j
http://www.ebay.co.uk/itm/KYB-Shock-Abs ... Sw9ZdXK0AT
I know it says for the 827 but they are the same unless your Coupé is a turbo? The turbos had lower suspension (by about 20mm) and slightly shorter shocks, it could be standard length shocks have been fitted already though.
My brother did a similar thing years back in an 820. He slid off the exit of an island square into a central reservation at about 15MPH. Both right side wheels were tucked under by at least 2".
The car wasn't worth much and he was due to have his license revoked shortly after so it got stripped. I never even considered fixing it as it could easily have done a lot more damage than was obvious.
Hi,Dave, I would rather replace them now than find damage later...I was doing about 25mph, pouring rain, hit OS kerb, over-corrected, and car went sideways into NS kerb, bit of a bang, and it has done all that...so insurance claim now, keep the salvage, and get it fixed...
If you have the hubs, I would be pleased,and thanks for the link for shockers, the car is normal 2 litre, until I can find a Vitesse coupe !
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
That makes sense Dick, i've been suffering the lurgy for the past few days so haven't checked what bits i've got (someone else is after a few bits that i need to check for too) but fairly sure i have them. It would make sense to renew the ball joints as well when you fit the new hubs, just to be on the safe side and it's a lot easier with the front hubs already off!
Just be careful when you claim on the insurance they don't try and firstly take the car and secondly write it off in one of the categories where you can't put it back on the road!
Thanks,Dave,
when you get the time, please let me know what you have got...I have an assessor coming on Monday, they know I want to keep the car, and it should be a Category C write-off..
Dick
Dick
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
Will do!
Only just noticed you're in Cambridge!
If you ever fancy a cuppa or other beverage and a natter just let me know
More Caxton Gibbet way Dusan! Unless he's moved since i dropped off the sills......
Yes,Dave, still here...
Hi,Dusan, do you go to the Fowlmere meets?
Would be good to cheew the fat with you some time..!
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
