eBay 820 vitesse
- Location: Suffolk [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
eBay 820 vitesse
Anyone have any knowledge of this car, currently advertised on eBay. V564VUD 1999, 820 vitesse 2.0 in Essex?
Is it worth a small bid?
Re: eBay 820 vitesse
NO MOT, but he says it runs ok.
He says its all good , but me thinks it maybe a bit tatty.
Major dashlift
back window open
mirror bent
wrecked rear bumper , scuffs to front one.
cant see seat squabs in pics
Could be a decent motor with a little tidy up , but I wouldn't pay too much for it.
Major dashlift
back window open
mirror bent
You mean this one then?
http://www.ebay.co.uk/itm/1999-ROVER-82 ... OSwNphWXLt~
Dash lift is fixable with a hot day (or a fan heater inside the car), a tub of Evostik, some spring clamps and pieces of wood to spread the clamping effect and i'm sure Dean has a back bumper for sale if you ask him nicely!
Other than that, it's a recent MoT failure needing welding, brake pipes, brake discs and several other major things including lower ball joints on the front and CV gaiters (can do the gaiters while the hubs are off to do the ball joints) and the horn and some bulbs need fixing :
Check the MOT history of a vehicle
Registration number: V564VUD
Mileage readings are currently only available for MOTs done from 1 August 2011.
Vehicle make ROVER Vehicle model 820 Date first used 16 September 1999 Fuel type Petrol Colour Blue
MOT history of this vehicle
Test date 10 September 2015 Test Result Fail Odometer reading 83,688 miles MOT test number 9429 0951 3774 Reason(s) for failure
Horn not working (1.6.2a)
offside Registration plate lamp not working (1.1.C.1d)
offside rear Suspension component mounting prescribed area is excessively corroded outer sill near trailing arm mounting point (2.4.A.3)
offside rear Body has a sharp edge caused by damage bumper (6.1.C.1)
offside front Brake pipe excessively corroded (3.6.B.2c)
offside rear Brake pipe excessively corroded (3.6.B.2c)
nearside rear Brake pipe excessively corroded (3.6.B.2c)
offside front inner Tyre has a tear, caused by separation or partial failure of its structure (4.1.D.1b)
nearside front front brake binding (3.7.B.1)
Advisory notice item(s)
brake disc worn, pitted or scored, but not seriously weakened front and rear (3.5.1i)
air bag light does not come on
offside outer Front suspension has slight play in a lower suspension ball joint (2.5.B.1a)
nearside outer Front constant velocity joint gaiter deteriorated, but preventing the ingress of dirt (2.5.C.1a)
nearside front Anti-roll bar rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Test date 23 September 2014 Expiry date 22 September 2015 Test Result Pass Odometer reading 83,610 miles MOT test number 1889 1686 4274 Advisory notice item(s)
Nearside Inner Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Inner Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Front Brake pipe slightly corroded (3.6.B.2c)
Nearside Outer Front constant velocity joint gaiter deteriorated, but preventing the ingress of dirt (2.5.C.1a)
Offside Outer Front constant velocity joint gaiter deteriorated, but preventing the ingress of dirt (2.5.C.1a)
Offside Outer Front suspension has slight play in a lower suspension ball joint (2.5.B.1a)
Test date 16 September 2014 Test Result Fail Odometer reading 83,610 miles MOT test number 9261 2925 4259 Reason(s) for failure
Supplementary Restraint System warning lamp indicates a fault (5.4.2)
Test date 4 September 2013 Expiry date 10 September 2014 Test Result Pass Odometer reading 83,450 miles MOT test number 5788 7754 3257 Advisory notice item(s)
rear brake inner discs corroded
Test date 4 September 2013 Test Result Fail Odometer reading 83,450 miles MOT test number 3350 9774 3430 Reason(s) for failure
Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside front brake binding (3.7.B.1)
Test date 11 September 2012 Expiry date 10 September 2013 Test Result Pass Odometer reading 83,399 miles MOT test number 6271 4565 2202 Advisory notice item(s)
Nearside Outer Rear Upper Brake pipe slightly corroded (3.6.B.2c)
Offside Outer Rear Upper Brake pipe slightly corroded (3.6.B.2c)
Offside Outer Front Brake pipe slightly damaged (2.2.D.2b)
Nearside Outer Front suspension has slight play in a lower suspension ball joint (2.5.B.1a)
airbag light on
offside front brake binding on slightly
offside and nearside outer rear lower sills getting weak with corrosion
Test date 11 September 2012 Test Result Fail Odometer reading 83,399 miles MOT test number 3593 7565 2412 Reason(s) for failure
Offside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Nearside Rear Direction indicator incorrect colour (1.4.A.2f)
Offside Rear Direction indicator incorrect colour (1.4.A.2f)
Offside Rear Upper Body has a sharp edge caused by damage (6.1.C.1)
airbag light on
Test date 14 July 2011 Expiry date 13 July 2012 Test Result Pass Odometer reading 83,245 miles MOT test number 1078 1569 1134 Advisory notice item(s)
Front constant velocity joint gaiter deteriorated (2.5.C.1a)
o/s front brake slightly binding
rear inner brake discs slightly corroded
Test date 8 July 2010 Expiry date 7 July 2011 Test Result Pass MOT test number 4638 2918 0179 Advisory notice item(s)
Offside Outer Front constant velocity joint gaiter deteriorated (2.5.C.1a)
Test date 5 July 2010 Test Result Fail MOT test number 9412 8638 0102 Reason(s) for failure
Front registration plate delaminated (6.3.1d)
Nearside Registration plate lamp not working (1.1.C.1d)
Nearside Rear rear parking brake recording little or no effort (3.7.B.6a)
Offside Rear rear parking brake recording little or no effort (3.7.B.6a)
Parking brake: efficiency below requirements (3.7.B.7)
Test date 22 June 2009 Expiry date 27 June 2010 Test Result Pass MOT test number 4803 1397 9196 Advisory notice item(s)
Nearside Front Anti-roll bar has slight play in a pin/bush (2.4.G.2)
Offside Front Anti-roll bar has slight play in a pin/bush (2.4.G.2)
Rear Exhaust has a minor leak of exhaust gases (7.1.2)
Rear Exhaust has part of the system slightly deteriorated (7.1.1a)
front number plate slightly disfigured
Test date 18 June 2009 Test Result Fail MOT test number 2703 1946 9414 Reason(s) for failure
Anti-lock braking system warning lamp indicates an ABS fault (3.4.1c)
Nearside Inner Rear brake disc excessively pitted (3.5.1h)
Offside Inner Rear brake disc excessively pitted (3.5.1h)
Offside Rear rear brake binding (3.7.B.1)
Test date 18 June 2008 Expiry date 27 June 2009 Test Result Pass MOT test number 2228 0067 8410
Test date 18 June 2008 Test Result Fail MOT test number 7508 2057 8107 Reason(s) for failure
Nearside Rear Stop lamp not working (1.2.1b)
Offside Rear Stop lamp not working (1.2.1b)
Centre Rear Stop lamp not working (1.2.1b)
Test date 28 June 2007 Expiry date 27 June 2008 Test Result Pass MOT test number 9931 7907 7105 Advisory notice item(s)
n/s rear wheel bearing slightly noisey
Needs a front tyre as well. If you could get it cheap enough and do most if not all of the work yourself then it would be viable to return to the road. Failing that, it's a breaker sadly as on the face of it, it's a nice looking car.
It's done 87 miles since that MoT test - bearing in mind the name of the seller, it either broke down or was abandoned near them or they thought they could make a profit on it then found out what it needed for the MoT.
airbag light on
airbag light on
thats been up for sale on eBay a few times now, some of the feedback isn't that spectacular either, ok if you can nab it for cheap monies.
fleet now includes
Those long lists of advisory and fail items mean either a very fussy MOT tester or a neglectful owner who only carries out maintenance to get a ticket.
traineefarmer wrote:Those long lists of advisory and fail items mean either a very fussy MOT tester or a neglectful owner who only carries out maintenance to get a ticket.
I'd suggest the second option - the horn has been failed several times for example. Also there's nothing to say it was the same test station every time so maybe it's always had these faults and the bare minimum has been done to scrape it through.
Would make a good spares car though if it was cheap enough.
Thank you gentlemen for the information and comments. This car doesn't seem to have been loved/cherished by previous owners. I was thinking of trying a small bid but maybe it's more suitable as a source of spares.
Cheers, Chris
Cheers, Chris
True, but it all sounds fixable if you are handy eough, (though prob not worth it if you are paying someone time)
(1997 820Si / LPG)
(1997 820Si / LPG)
You're welcome Chris and also welcome to the forum.
Some might say we've been over-critical but it's not impossible to put back on the road. For example, you could almost certainly fix the horns by fitting new ones for about a tenner, a new pair of budget radials for the front for about £60-70 (you'd have to get them fitted or fit them yourself), the anti-roll bar bushes are still available from Rimmers for just under a tenner each :
http://www.rimmerbros.co.uk/Item--i-RBX100500
then it's the welding, a number plate bulb and the brake pipes and a bit of a clean/grease of the front caliper and maybe a set of pads. The rear discs appear to be in need of replacement too but they have only been an advisory up until now so you could replace them through the year. Other than that, it's another bumper (or a roll of duct tape to cover the damage/sharp edges) and you should be within sight of a fresh MoT ticket. After that it would be a case of going through the car throughly, attending to things that have been skimped on over the years and putting them right but you'd have what is now a fairly rare car that should start to appreciate in value anytime soon.
Depending on your location and peoples personal schedules, you might even find that some help is at hand to get things sorted on it.
I've got a stack of metal family choice biscuit tins if it helps, left over from my mk2 escort owning days
fleet now includes
midnite wrote:I've got a stack of metal family choice biscuit tins if it helps, left over from my mk2 escort owning days
Give them to a Peugeot owner Matt - they could do with some quality metal in their cars!
- mjc9967
Are there any biscuits left?
yeah the shortbread rectangley ones with the striped section round the outside, they is orrible
fleet now includes
- mjc9967
haha no such thing as a bad one once its dipped in tea
- BlueRover
Gorilla glue for the dash lift. Mind it doesn't drip over anything else or that will be stuck forever too.
Users browsing this forum: Google [Bot] and 23 guests
