colour blind duo tone coupe
midnite
Post by midnite » Thu Jan 07, 2016 8:27 pm
seriously, read the write up, cherished by its last owner, previous owners 7, what did they do before the last guy got his hands on it for ten minutes.
and gold n green duo tone, words fail they really do.http://www.ebay.co.uk/itm/1995-ROVER-82 ... SwwPhWjq6l
fleet now includes
deano
Re: colour blind duo tone coupe
Post by deano » Thu Jan 07, 2016 9:07 pm
where ?
rovercoup
Post by rovercoup » Thu Jan 07, 2016 9:48 pm
deano wrote:where ?
WTF, It just down the road from scooby. Ask nicely he might pop out and throw up on it to improve the look.
Sorry thats not very nice. it is not my car so they can do whatever they like with it but IMO it does nothing for the styling of the car but in a perverse way I keep looking at it. Strange!!!! :?
deano
Post by deano » Thu Jan 07, 2016 10:17 pm
Oh , you`ve put the link up now :?
Looks in good nick , couple of hundred quid to have that green blown over properly...
cd player loose in boot ? probably broken...
Seems like plenty of interest in it
Post by scoobyh123 » Thu Jan 07, 2016 10:45 pm
rovercoup wrote:
deano wrote:where ?
It looked passable last time i saw it in the Aldi car park in Brandon but then the bumpers were from a Nightfire Red car and hadn't been painted Vomit Green!
Just for fun i might turn up there in my Jeep tomorrow and feign interest in it - then explain there never was a VDP model in the 800 series and the idiot that painted it greeen needs neck-shooting! :evil: :evil: :evil:
Double checked on Googlemaps it was the one i thought it was and it's 5.7 miles or 12 minutes drive or an hour and 3 minutes by public transport from me! No wonder people won't use public transport!
Anyway, looks like i'll use £1.50's worth of gas and go see this beast.
mjc9967
Post by mjc9967 » Fri Jan 08, 2016 10:42 am
It is strangely attractive isnt it!
Looks good condition - I wonder if the (recent?) funny paintwork is hiding any soon-to-return rust etc?
Post by scoobyh123 » Fri Jan 08, 2016 11:55 am
mjc9967 wrote:It is strangely attractive isnt it!
Check out the MoT History!!!
Check the MOT history of a vehicle
Registration number: M366DBY
Mileage readings are currently only available for MOTs done from 1 August 2011.
Vehicle make ROVER Vehicle model 827 Date first used 31 December 1995 Fuel type Petrol Colour Gold
MOT history of this vehicle
Test date 23 January 2015 Expiry date 5 February 2016 Test Result Pass Odometer reading 126,775 miles MOT test number 2160 3352 5098
Test date 14 January 2014 Expiry date 5 February 2015 Test Result Pass Odometer reading 121,258 miles MOT test number 6761 0481 4058 Advisory notice item(s)
Nearside Front position lamp(s) deteriorated, but still visible from a reasonable distance (1.1.A.3d)
Offside Front position lamp(s) deteriorated, but still visible from a reasonable distance (1.1.A.3d)
Nearside Front suspension has slight play in a lower suspension ball joint (2.5.B.1a)
Offside Front suspension has slight play in a lower suspension ball joint (2.5.B.1a)
Nearside Front Upper Suspension arm has slight play in a pin/bush (2.4.G.2)
Offside Front Upper Suspension arm has slight play in a pin/bush (2.4.G.2)
Nearside Rear Shock absorber has a light misting of oil (2.7.3)
Offside Rear Shock absorber has a light misting of oil (2.7.3)
Nearside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Supplementary Restraint System warning lamp does not illuminate (5.4.2)
Play in steering rack inner joint(s)
o/s outer sill corroded but not yet considered excesive
both rear tyre cracked and perrished
brake pipes slightly corroded
Rear bumper insecure
Test date 13 January 2014 Test Result Fail Odometer reading 121,251 miles MOT test number 1577 9301 4018 Reason(s) for failure
Supplementary Restraint System warning lamp indicates a fault (5.4.2)
Battery insecure (1.9.1)
Nearside Headlamp aim too low (1.8)
Test date 6 February 2013 Expiry date 5 February 2014 Test Result Pass Odometer reading 120,956 miles MOT test number 1897 5773 3044 Advisory notice item(s)
Offside Rear Shock absorber has a slightly worn bush (2.7.4)
Rear Exhaust has a minor leak of exhaust gases (7.1.2)
nearside and offside front tyre cracking on tread
Test date 6 February 2013 Test Result Fail Odometer reading 120,956 miles MOT test number 3955 9763 3077 Reason(s) for failure
Nearside Front Side repeater not working (1.4.A.2c)
Nearside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Rear Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Test date 13 March 2012 Expiry date 17 March 2013 Test Result Pass Odometer reading 119,387 miles MOT test number 4493 2357 2065 Advisory notice item(s)
srs light shows a fault
Test date 18 March 2011 Expiry date 17 March 2012 Test Result Pass MOT test number 6760 3737 1037
Test date 12 March 2010 Expiry date 17 March 2011 Test Result Pass MOT test number 4546 2117 0062
Test date 12 March 2009 Expiry date 17 March 2010 Test Result Pass MOT test number 8514 1137 9018 Advisory notice item(s)
Rear Brake pad(s) wearing thin (3.5.1g)
n/s/f brake holding slightly
advise attention to n/s bonnet catch
Test date 9 March 2009 Test Result Fail MOT test number 2536 9896 9038 Reason(s) for failure
Offside rear parking brake recording little or no effort (3.7.B.6a)
Parking brake: efficiency below requirements (3.7.B.7)
Test date 18 March 2008 Expiry date 17 March 2009 Test Result Pass MOT test number 5243 2827 8061
Test date 14 March 2008 Test Result Fail MOT test number 2046 1497 8083 Reason(s) for failure
Body insecure and dangerous to other road users (6.1.B.1b)
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.3)
Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.D.3)
Parking brake lever has no reserve travel (3.1.6b)
Anti-lock braking system warning lamp indicates an ABS fault (3.4.1c)
Test date 31 May 2006 Expiry date 30 May 2007 Test Result Pass MOT test number 5805 9125 6191 Advisory notice item(s)
slight uplift front lower ball joints
slight imbalance front brakes
Odd that 2 years ago there was a long list of advisories yet nothing last year???
Post by scoobyh123 » Fri Jan 08, 2016 2:46 pm
Well i went to have a laugh - err a look at this coupé only to find it has been sold already! Apparently a dealer near Ipswich turned up with a trailer and paid £650 for it. My guess is he'll repsray the bottom half in the correct colour and have it up for sale for about £2000 in a few days time.
mercedade
Post by mercedade » Sun Jan 10, 2016 10:33 pm
scoobyh123 wrote:Odd that 2 years ago there was a long list of advisories yet nothing last year???
Probably finally seen by an MOT tester who didn't feel the need to mention every single thing which passed his or her eyeballs 'just in case'.
There does seem to have been an outbreak of common sense recently - overheard a couple of testers discussing advising on a non-working nearside rear fog light, and the conclusion was "what's the point? It'll only p*** them off, and it's not testable anyway". Instead they were just going to mention it to the customer in case they didn't know.
I wanted to give them a round of applause.
To be fair, the overwhelming majority of testers I've ever come across have been top quality - I've got no complaints, but maaaaaaaaaaaan I've seen some stupid advisories in the past.
Post by scoobyh123 » Sun Jan 10, 2016 10:40 pm
True enough but if you look on the advisories from about 2 years back, most of them are known trouble spots on the 800 as a whole (although some points were just picky!) and things like weeping shocks, knackered brake discs, dodgy front lower ball joints etc shouldn't have been ignored - we all know what happens when the bottom ball joints fail! I think it was Tim (WhiteLion) that had one go during a holiday a few years back on his blue coupé and posted a photo up - ruined the wing, not to mention the tyre and his holiday too!
Just rechecked the MoT history and it's not been retested yet, i think the buyer will paint it then put it up for sale for about £2k with a new test on purchase - time will tell i suppose on that score.
