Fancy A "Frog-eye" Scorpio, Anyone?
- Seans Dad
I thought I'd share my troublesome, short-lived love affair with the Ford Scorpio, the last of Ford's big, rear wheel drive cars.
The Frog-eye, introduced in 1994, received much criticism from the press for its ungainly looks, especially in saloon form, but I think the estates pictured here are actually quite attractive.
I owned three, and still have the Green one, although not for too long hopefully!.
Here goes, in order;
My first Scorp, bought in April 2008, was this stunning 1997 2.3 4cyl Ultima Auto, top of the range model. I paid £450 for it, as it had a short MOT, but when MOT time came along in June, it went straight through, with no work required!! I was amazed, and was looking forward to a years trouble free motoring in it, but in September 2008, the engine over-heated, and the cooling system was over-run with horrible brown sludge.
It turned out that the cylinder head had cracked, on the oilway between cyl's 3 & 4, a common problem on these engines. I flushed the engine through, and it ran better, but I cut my losses, and sold it on for spares;
As I'd fallen in love with the model, I immediately set out for a replacement, when along came this beauty, a 1994 Ghia Auto, with the 2.9 24v Cosworth engine. An awesome car to drive, it just pulled and pulled. I paid £480 for it, and it had long tax & MOT.
It towed our caravan down to Weymouth for a long weekend break, and was brilliant, until three weeks after returning, the gearbox cried enough, and lost forward drive. Looking at another huge bill for a replacement, I again sold it on, and looked for another one;
I then picked up this 1996 Ghia, a 2.0 16v with manual 'box, and hardly any MOT. I'd been knobbled though, as when I took it for the MOT, it failed on emissions.
I still have this at the moment, but it is listed on ebay, finishing this coming Sunday. I wasn't as impressed with this one as I was with the other two, and I think it killed my love for the Scorpio.
You could say that 2008 was a bad year for me and cars, but hopefully, with the Sterling, I can put most of my troubles behind me, and look forward to some decent motoring again!
Thanks for looking all.
Dan.
Dan.
1999 Mercedes C Class C240 Sport Auto Estate.
Previous Rovers: '94 827 Sterling Fastback Auto, '91 820si Fastback Auto.
http://www.mgt-dist.co.uk
- JulianO'Connor
- Location: Norfolk [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
- Seans Dad
I had no HG trouble on my Cosworth Richard, it was the 2.3 four cylinder engine that had a cracked cylinder head. The gasket was fine, as there was no oil or water leakage from it.Richard C wrote:I had a scorpio Cosworth for a few months HGF on mine as well, lovely to drive pug ugly but the Cosworth engines are fragile IMO
I wouldn't say that the Cosworth engine was fragile as such, but they did need a bit more looking after than your average 4-pot. The good thing was, they had good old fashioned timing chains, designed to last the life of the engine, so if anybody selling you one ever said: "Oh yeah, the cam belt's been changed", they are LYING!
Dan.
- JulianO'Connor
- JulianO'Connor
- Richard C
yes i must have had a duff oneSeans Dad wrote:I had no HG trouble on my Cosworth Richard, it was the 2.3 four cylinder engine that had a cracked cylinder head. The gasket was fine, as there was no oil or water leakage from it.Richard C wrote:I had a scorpio Cosworth for a few months HGF on mine as well, lovely to drive pug ugly but the Cosworth engines are fragile IMO
Dan.
@Rich_Clements
@Rich_Clements
- Seans Dad
Basically Richard, it needs a new catalystrichard moss wrote:Dan, any idea what's causing the trouble with the latest Scorpio and it emissions?
Here's the readings from the test:
Fast idle test
CO level=3.26% vol, max allowed is 0.30 = FAIL
HC level=75ppm = PASS
Lambda=0.911 = FAIL
2nd fast idle test
CO level=2.66% vol= FAIL
HC level=86ppm= PASS
Lambda=0.924= FAIL
Natural idle test
CO level= 4.03% vol, max allowed is 0.50= FAIL
Overall test result=FAIL.
As can be seen, the CO levels are dangerously high, and this would also affect the Lambda test IIRC.
The manifold end does blow quite badly on cold start, but it disappears after engine is up to temp.
I'm looking at around £400 to have a new catalyst fitted. Not only that, there is minor corrosion on the rear subframe both sides, which the tester said would need attention before it's next MOT in 2010, so weighing up costs etc, it's just not worth spending the money on the cat, only to shell out again for welding next year.
It also failed on poor handbrake efficiency, which I was aware of beforehand anyway. This is a five minute adjustment job.
Dan.
Dan, those CO levels are too high to pass a non-cat test - there has to be more to it than the cat. The old classic on the 820 (and XJ40) is the coolant temperature sensor failing and telling the ECU that the engine is cold, even when it is fully warm. It then continues to fuel as per a cold start.
The CTS on an 820 is under a tenner - I wonder what they cost on a Scorpio?
