300... that all. Is that all around town ?
I used to get 300 from the v6 models
New guy here
Re: New guy here
- Joined: Thu Jan 30, 2014 5:15 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: New guy here
All around town, so it's never going to be as good as motorway driving but it's definitely using too much I think, but by how much I'm not sure.
Re: New guy here
my 300 was a mix of motorway and town.
motorway 60/40 town.
Re: New guy here
After you have checked the thermostat I would then go on to replace the coolant temperature sensor and possibly the gauge temperature sender if the gauge reading still plays up. 20 to the gallon is well rich if you are staying off boost, should be more like 25-27 around town as long as your town dont involve 30 min traffic jams at every road junction. 65mph motorway driving should see closer to 40mpg on a good "T" series.
Thermostat, cts and gauge sender are all on the stat housing and so all can be done at the same time and that rules out the whole assembly then should further investigation be warranted.
Re: New guy here
Spot on advice Dave as I had the same with the coupe and once I had replaced the aforementioned items the car drives much better and has a stable temp gauge reading at about 8 O'clock.
