Very happy boy now,
Went out after my dad rang me while on lunch"check all the fuses under the dash"he said.
Not feeling hopeful I did as told and lo and behold the abs 10 amp fuse under the dash had a gap. New one put in and now the light goes off.
Maybe after years of non use when they put the battery on it,Maybe it surged the system.
Thanks again everyone from a very happy man
abs light problem diagnostic not working
- Location: Plymouth, Devon [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: abs light problem diagnostic not working
i want lots of british cars got 1 want more
That's great news! As long as it stays out when you start moving it you should be fine - also explains why the self-diagnostic function didn't work!
scoobyh123 wrote:That's great news! As long as it stays out when you start moving it you should be fine - also explains why the self-diagnostic function didn't work!
Thanks I hope it stays out too
Users browsing this forum: Google [Bot] and 36 guests
