Charles827si
Post
by Charles827si » Tue Oct 16, 2018 9:32 pm
scoobyh123 wrote: ↑Tue Oct 16, 2018 9:07 pm
No worries Charles, thanks for checking anyway! I'll hunt down another Volvo Telesto eventually, i just don't have a spare for it at the moment.
These the ones Dave? x4 for 40quid and one has a tyre on it.
https://www.ebay.co.uk/itm/Volvo-S40-v4 ... :rk:1:pf:0
Charles 'Yorks'
"92 827 Coupe (manual)
"88 827sli Saloon (auto)
2011 Lexus IS220D F Sport
Post
by scoobyh123 » Tue Oct 16, 2018 9:40 pm
That's the kiddies Charles, yes. That set you found are in Oldham and want cash on collection so is a bit of a non-starter for me sadly. Only really need one though, without a tyre and preferably in reasonably good condition.
Charles827si
Post
by Charles827si » Tue Oct 16, 2018 9:43 pm
scoobyh123 wrote: ↑Tue Oct 16, 2018 9:40 pm
I was gonna suggest if you were interested, I could collect and store for you. Oldham isn't too far away for me, and I tend to travel to Manchester more often these days.
Charles 'Yorks'
Post
by scoobyh123 » Tue Oct 16, 2018 10:32 pm
Charles827si wrote: ↑Tue Oct 16, 2018 9:43 pm
That's a very kind offer Charles, thank you very much! Let me think on it as it's all very well you collecting them for me but somehow i've still got to get them back here. Suffering brain fade at the moment anyway so not much is making any sense!
Charles827si
Post
by Charles827si » Tue Oct 16, 2018 10:41 pm
scoobyh123 wrote: ↑Tue Oct 16, 2018 10:32 pm
Yeah no problems, if it helps I could meet you somewhere half way to exchange these.
Charles 'Yorks'
Post
by scoobyh123 » Sun Oct 21, 2018 2:51 pm
Thanks again for that kind offer as well Charles - after a lot of long, deep thought i've decided my best bet would be to get a single wheel as a spare or at least if it is a set, somewhere close enough to collect within about an hours drive.
Looking on Gaggle Mops, Grantham would be the nearest to a mid-point between you and me and that looks to be about 90 miles from Keighley and also from Lakenheath - that's quite a way for both of us!
At the moment, unless i want to pay £65 for a single wheel, the only one around is this one :
https://www.ebay.co.uk/itm/Excellent-Vo ... 3182079009
Big benefit of that one is it includes free postage, so no worries on collecting/delivering or whatever. It's the same size, offset, PCD as the others, just looks a little different. The tyre is still wrong but will be ok as an emergency spare until i find a part-worn of the same make etc as the main tyres.
Charles827si
Post
by Charles827si » Mon Oct 22, 2018 9:12 am
scoobyh123 wrote: ↑Sun Oct 21, 2018 2:51 pm
No problem Dave! This sounds like the better option as you say, and hope it works out.
Charles 'Yorks'
Charles827si
Post
by Charles827si » Fri Nov 02, 2018 1:10 pm
I received my new 3D printed bumper brackets (many thanks Mark) and they do look and feel very good quality.
I took the rear bumper off the car with the aim of removing the old brackets. As you'll see in one of the photos I encountered slight problems with the rusty screws. So question I have is, whats the effective method to remove? I had wondered about drilling them out. Using an angle grinder seems extreme.
I did manage to usefully spray coat the bumper bar with wax oil. I have to say though its held up really well in the 5/6 years since Brads very liberal use of paint protection.
Charles 'Yorks'
Post
by scoobyh123 » Fri Nov 02, 2018 1:22 pm
I'd try some WMP Charles - 50/50 mix of acetone and synthetic ATF. Shake it well and then dribble/spray it onto the screws, sealing it up afterwards. Needs shaking before each use as well.
Once it's worked its magic on the screws, use a good Pozidriv screwdriver, preferably one where the blade goes all the way through the handle. Set the point of it in the screw head and give it a tap with a hammer, turning slightly anti-clockwise as you do it. If you can get behind the panel to get some WMP on the back of the threads, do that as well.
Once you get the screw moving, go back and forth with it so you're alternately tightening and loosening, applying a bit more WMP as you go. Takes time but is almost guaranteed to get the screws out in one piece.
Charles827si
Post
by Charles827si » Fri Nov 02, 2018 1:28 pm
scoobyh123 wrote: ↑Fri Nov 02, 2018 1:22 pm
I bet that works far better than WD40 in a spray can.
Charles 'Yorks'
Post
by scoobyh123 » Fri Nov 02, 2018 1:34 pm
It does indeed! I mutilated an empty carb cleaner aerosol and fitted the brass body/valve core from a tyre valve into the bottom.
Then removed the valve core and used syringes to fill the can with ATF-U followed by the same amount of acetone.
Refit the valve core and stick 120psi of compressed air in it. Shake and squirt!
Most aerosols use 250-260psi of propellant pressure so 120psi isn't a problem.
Charles827si
Post
by Charles827si » Fri Nov 02, 2018 1:40 pm
scoobyh123 wrote: ↑Fri Nov 02, 2018 1:34 pm
Great uses of ingenuity, did the spray work on first try?
Charles 'Yorks'
Post
by scoobyh123 » Fri Nov 02, 2018 1:56 pm
It certainly did Charles! Still does in fact. The only one that didn't was the previous WD40 can i tried, the rubber or whatever in the spray valve isn't resistant to acetone so blocked up.
That's why i picked the carb cleaner aerosol as a donor can to use.
Charles827si
Post
by Charles827si » Fri Nov 02, 2018 3:34 pm
I guess, failing this I would drill out the screws.. but I'm prepared to try anything at least once.
Charles 'Yorks'
Post
by scoobyh123 » Fri Nov 02, 2018 5:28 pm
Give it a go Charles, hopefully you'll be lucky! If not, i'd suggest a Dremel or similar to grind the head off the screw so you've got a bit of thread to clamp some Mole grips onto and turn it this way/that way to get it moving with more WMP on the threads.
1266:
Users browsing this forum: No registered users and 52 guests
