It's the time of year again for the dreary MOT (and I almost forgot about this year having realizing last night the expiry date is Monday September 3rd
I booked the coupe in to a local test centre (different centre to usual). There was a slight delay with the test because the previous customer was late to the test with her Hyundai.
So over two hours later, I got the results which are below as follows: -
Date tested
30 August 2018
Fail
Mileage
160,278 miles
MOT test number
1337 6699 4084
Test location for this MOT test will be available in 14 days.
Repair immediately (major defects):
•Nearside Front Upper Suspension arm pin or bush excessively worn Top wishbone bushes. (5.3.4 (a) (i))
Monitor and repair if necessary (advisories):
•Oil leak, but not excessive (8.4.1 (a) (i))
•Offside Front Bumper mountings corroded but not likely to become detached (6.1.4 (a) (i))
•Nearside Rear Bumper mountings corroded but not likely to become detached (6.1.4 (a) (i))
•Offside Rear Bumper mountings corroded but not likely to become detached (6.1.4 (a) (i))
•Nearside Rear Inner Integral body structure or chassis corroded within 30cm of a mounting, but not seriously affecting overall security Wheel arch. (6.2.2 (d) (i))
•Offside Rear Inner Integral body structure or chassis corroded within 30cm of a mounting, but not seriously affecting overall security Wheel arch. (6.2.2 (d) (i))
•Nearside Rear Fuel filler pipes corroded.
So as you can see one major fail recorded and several advisories.
Thank heavens there have been no brake failures or advisories considering how much work and money has been put into the entire braking system over the past year.
I have already managed to locate the part which I need which is the bearing assembly-upper arm front suspension - (RBP100050). The bushes have worn and as I saw for myself, the wheel had more than a slight wobble when rocked from the sides.
The part isn't at Rimmers currently (back order listed for £56.87 inc VAT) but I have checked on MG Rover part finder. There are x4 of this part supplied by AE Wilcox. Judging by Rimmers price, I'll probably pay slightly less, since previous purchases have always been less expensive.
This will be ordered tomorrow and with first class post I should have it Saturday.
With any luck the part can be fitted over the weekend in time for the retest on Monday 3rd - the same date the current MOT expires...fingers crossed!
