Post by Manalishi » Mon Mar 01, 2021 12:54 pm
Excellent! Thanks Dave!
Post by scoobyh123 » Mon Mar 01, 2021 1:07 pm
You're welcome Henrik, good luck and let us know how it goes! :wink: :D
Post by Manalishi » Sun Apr 11, 2021 4:08 pm
Spring is here and so was my starter switch! Fitted it just now, very easily done. The steering column cowl was already off and the switch itself is only held by two very small screws. S bit fiddly but not hard.
The switch has two multiplugs/connectors in the loom and they both go into the front of the switchboard.
I swapped the plugs aswell. It’s quite obvious that those that were in the car when I got it is better. Maybe the non cat versions likes these better but it’s a mystery why they were there really. I am a bit surprised really as I prefer NGK but these Beru Ultra X gives the car a nice extra grunt in power. Noticable! And the fuel goes down too!
Hopefully the new switch Will do the trick so I can use the car from now on.
Post by scoobyh123 » Sun Apr 11, 2021 4:11 pm
Excellent work henrik! FIngers crossed that's the problem solved!
Interesting about the plugs too! :wink: :D
Post by Lodein » Sun Apr 11, 2021 5:18 pm
Good job
I hope that the problem is fixed now
Post by Manalishi » Sun Apr 11, 2021 5:56 pm
Thanks guys! I hope it’s fixed too, there is nothing as bad as a unreliable car when it comes to starting. I really hope the switch does it, all connections and earth straps are ok so shouldnt be a problem.
Next is to sort some niggling electric gremlins I never got time for last year.
Post by Manalishi » Mon Apr 12, 2021 6:37 pm
A short trip today. No problem. Knock on wood! :lol:
Fastback
Post by Fastback » Mon Apr 12, 2021 7:22 pm
Or should that be 'Touch burr walnut'?
Glad to hear it Henrik.
'99 Sterling KV6 Fastback :D
Post by scoobyh123 » Mon Apr 12, 2021 11:46 pm
Fingers crossed that's it sorted! :wink: :D
Post by Lodein » Tue Apr 13, 2021 10:30 am
Good news
Post by Marc-827-Vitesse » Wed Apr 14, 2021 9:37 pm
Good that the it worked!
Post by Manalishi » Mon Apr 19, 2021 6:10 pm
The Black Vitesse is still running as it should, so hopefully the starter switch did the trick.
Now I have a new small niggling fault that started during the last few weeks of last season really, but I never bothered. I think it's ABS-related. As I drive away, the first time I put my foot on the brake pedal I have two short beeps. I presume it's somekind of fault code that is possible to understand. From time to time I also get a small rattle from the brake pedal, just like when the reluctor rings are worn, dirty etc.
When I had the car running from the beginning the abs light was on, and after measuring all of the sensors and working the system quite thoroughly, I bypassed the light. The ABS doesn't work anyway. (tried them).
So I presume it's ABS-related. Any ideas? Anyway of disconnecting the abs for sure?
Post by scoobyh123 » Mon Apr 19, 2021 6:58 pm
This one is a puzzle Henrik - are they electronic beeps or more of a double-squeak from the brake system? Usually about 8mph (~15kmh) immediately after pulling away after starting the engine?
Post by Manalishi » Tue Apr 20, 2021 4:41 am
Electronic beeps Dave. It comes from the switch board area from What I can tell.
Post by scoobyh123 » Tue Apr 20, 2021 10:17 am
That's an odd one Henrik, sounds vaguely familiar from my time with a Mk1 Sterling, do you have any warning lights on at all?
