Simon's Vitesse Coupe
I spotted it!! I did, i did, i did!! Can i have the lollipop? Oh go on, please, please, please? Oh. You've already posted the answer!
I've always wondered what it would look like with the reverse of what you have there, where the new bumper has the gold on the bumper line and black below, have gold below and a black bumper line. Come the warmer weather i might just buy some black Fablon or wide insulation tape and try it out.
On the other hand, I think that the black sills on an 800 coupe make them look lower and more sleek than the saloons.Manalishi wrote:I once had an Audi 80 -88. A white one and the sills were normally black, but these were all white. The car looked instantly 30-40mm lower than others like it. Paint is great for illusions!
Exactly what I was going to say. A lot VWs etc are like it now as all cars have grown in size.Richard Moss wrote:On the other hand, I think that the black sills on an 800 coupe make them look lower and more sleek than the saloons.
Well the good news of the day is that the coupe passed its MOT.
It had 2 advisories, rear box - which was noted last year so i am surprised it has lasted this long and a pipe which has some corrosion on it. I took a picture of it earlier so i will post again when i have loaded it to photobucket.
All other things were fine especially the emissions which were excellent for a car with 150k on the clock.[/b]
As I mentioned there were 2 advisories, one of them the back box and this pipe.
It is near to the fuel tank/pipes from the filler tube. What is it please and what should i do about it?
The picture is not that clear but it is the pipe in the centre of the picture and is partly covered by a little plastic cover.
Thank you
Thank you
I whip off that plastic rust trap (sorry, cover), wire brush and treat to some Kurust then my favourite paint (you know - the one that begins with H).
It's one of the petrol pipes and that plastic cover is just a rust promoting device.
I've not seen one go right through - Kurust and paint has done the job so far. There are a load of skinny little fuel pipes between the tank and the floor of the car and they suffer badly, too - if you can get some spray rustproofer in there it might help them to last a bit longer. Access is pretty poor, though.
- Joined: Sun Sep 13, 2009 6:53 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
I think that's a brake pipe, on the nearside rear it goes via a 90' bend to join the rubber brake pipe to the calliper. and they use a metal block for it. I removed the cover on mine and cleaned and painted it. about 6 months later the rubber brake pipe were were it goes through a metal collier fitted to the suspension leg split . big problem trying to get a new brake pipe with that lump of metal on the end. had to go to a breakers and cut one off with about 2ft of the pipe that goes into the passenger area, and join it up to the existing.
300,000 mile white gold sterling on lpg Gone RIP
150,000 mile red sterling on lpg Still around
100,000 mile BRG rover sterling not on lpg Passed on
shiny blue jag on lpg
Another blue jag 2.5 auto
I'm with Rich. That's definitely one of the fuel lines "protected" by the mud trap plastic cover. I agree with Rich. Ditch the cover and H*****ite the pipes. I replaced mine on one of my Coupes a few months ago. It was a devil of a job. You need to lower the tank for proper access. However, I think I could now possibly bodge the job with some deft fingerwork and a length of pipe and clips. Nasty.
- whitelion58
Yep, its the mail fuel feed to the front of the car. My first gold Sterling chose to rust through at that exact point. I had the car ticking over on the yard for a few mins, came back to it to find a lake of petrol spreading under the rear of the car... Thankfully it stops when the engine is switched off, but makes the car pretty undriveable when it fails....
As Brad suggests, really need to drop the tank and replumb - with a mix of plastic fuel line and/or copper instead of the rubbish steel pipe Rover used to save a few pennies..
Tim
Tim
'86 825 Sterling Saloon
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
'90 827 Si Fastback
'94 Sterling Coupe
+ others.
