It really depends where it leaks from. If it's a join, some JB Weld/Chemical Metal may be worth a try.Mark827 wrote:Anyone any thoughts on whether the rad can be fixed, it only leaks when cold?
This weekend I've been mostly...........
- Mark827
- Location: Derby [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Been reading that JB Weld is recommended, I might try it.
Also popped to my local breakers yard at lunch time and there was an 820 with steering wheel and rotary coupler hanging off, its looks like it has same wires as mine albeit one extra, maybe for an airbag, don't think it had cruise though, but maybe the coupler may work.
'92 827 Coupe
'92 827 Coupe
- Joined: Fri Aug 29, 2008 10:30 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
- Mark827
I tested the continuity of the wires on the new coupler and they all seem good so I'll fit it. Not bad for saying I went to the local scrapper with no tools, one 800 in the yard and the coupler hanging off by the wire.
Good luck or what.
On a side note I love my newly modified exhaust, I've been thrashing it to the redline everywhere just to hear the exhaust at 6000 rpm, I never thought I'd be a fan of the big bore exhaust brigade as I hate noisy exhausts, but its addictive!
Good luck or what.
'92 827 Coupe
'92 827 Coupe
Welcome to the club.Mark827 wrote:On a side note I love my newly modified exhaust, I've been thrashing it to the redline everywhere just to hear the exhaust at 6000 rpm, I never thought I'd be a fan of the big bore exhaust brigade as I hate noisy exhausts, but its a addictive!
In my fastback that's the least of the problems noise wise.
- Lord Sterling
Same here, I loved it when my 827Si had the big bore exaust on it, too bad it had more holes than swiss cheese, but it still sounded fantastic. I'm thinking of putting a bigger exaust on my SterlingMark827 wrote:...On a side note I love my newly modified exhaust, I've been thrashing it to the redline everywhere just to hear the exhaust at 6000 rpm, I never thought I'd be a fan of the big bore exhaust brigade as I hate noisy exhausts, but its addictive!...
Lord Sterling
- Lord Sterling
- Mark827
Another weekend, another problem solved.
To start, 2 new Track Control Arms complete with new bushes, damn those big tie bar bolts are tight, I used 3 metal bars slotted together and both feet.
Also tested my plug leads as I had an irratic idle problem that was getting worse. Turned out No 4 lead was duff offering no continuity. Front leads should of read 8 ohms, rear leads 15 ohms. I swapped No 4 for a spare and so far so good.
'92 827 Coupe
'92 827 Coupe
Users browsing this forum: Google [Bot] and 10 guests
