Just thought I'd check in to say that I'm still here......just very, very busy! As well as my IT business (technology-systems.co.uk) I also now have a property development company (http://norfolkcounty.co.uk) which is currently building 5 large houses in Horsford. Sadly this means that time is a precious commodity!
I'm hoping to spend a little time on the Sterling soon. My project for the last 2 years has been our boat however hopefully that will be finished and back in the water in the next month or so and the Sterling will be the project after that. I'm currently arranging for it to be moved from the garage it's been stored in for the last few years back into the workshop in the yard at my office so that work can begin, although I probably should have started buying parts a while ago!
Where's Guru?
Where's Guru?
Guru - AKA James
m6jkk.com
Current Fleet
2015 Mercedes C300 Hybrid
2015 Mini Cooper SD
m6jkk.com
Current Fleet
2015 Mini Cooper SD
Re: Where's Guru?
Nice to hear from you James, although i fear madness may have taken hold. 5 houses!! just the 1 has had me nearly going nuts in the last 12 months.
good luck with your ventures
Re: Where's Guru?
Nice to see you around James, glad things are okay with you. How is the Merc going?
