Honda Leaking Petrol Tank.
My Honda Motor Bike has a leaking petrol tank. So far I have had no success at repairing it. I have tried Araldite, JP Weld and Granville Petro Patch. All leak again after a week. My lack of success is driving me nuts. There must be something out there that will do the trick. Looking for recommendations. The bike is thirty years old and so far I have not been able to locate a new tank.
1992 820SI saloon.
- t120v
- Location: pontgarreg ceredigion [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Honda Leaking Petrol Tank.
Hi I used Petseal many years ago & that worked well, you could also look at Slosh or Sureseal.
Russ
Russ
TVR 350i
Triumph T120V
Triumph T150V
HD FXRPS
Vitesse Mk1c
Triumph T120V
Triumph T150V
HD FXRPS
Vitesse Mk1c
Is it leaking on a seam and is the cause corrosion? I've had some success with the Granville stuff away from seams, but any leak on a seam is going to be nigh on impossible to fix.
- Tenesmus
Have you tried David Silver?
Pete
- metelmickey
- Location: hampshire [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
also try "frost auto products " they do a tank sealer, i have used it on a pontiac fuel tank and it lasted a few years and was still okay when i sold the car.
MIKE
just got a 827 mk2 coupe and loving it, more commanly known as mad mick ( used to run a nitros injected firebird ) still missing my rover, now got a BMW 735 1999. now got 2003 760l, a 6.0ltr V12 and 445bhp.
David Silver....
He plays for Man City doesnt he
- tonewheeldude
when I first bought the sunbeam it was leaking around the fuel outlet pipe. Took it off and got it brazed. that was over a decade ago and its still fine.
Practical Classics usually reccomend this stuff:
http://www.ebay.co.uk/itm/like/15188279 ... ue&ff13=80
Never used it myslef mind.
I have had limited success with petro-patches etc and have so far had replacement tanks on both my Allegro and Maxi for leaks.
(1997 820Si / LPG)
(1997 820Si / LPG)
Thanks gentlemen, all recommendations gratefully received and noted. The tank slopes down to the rear and I am guessing that water , being heavier than petrol, has settled out in this part of the tank when the bike was not used for a time and has caused the internal rusting. The holes are not on a seam. Both sides of the tank have gone but just one area has proved reluctant to seal. I think brazing may be the way to go. But only after draining the tank and thoroughly purging it of petrol fumes.
1992 820SI saloon.
- Tenesmus
What bike is it?
Pete
