the "mad maestro"
thamestyres
Re: the "mad maestro"
Post by thamestyres » Mon Dec 02, 2019 7:49 pm
the morris is very slow because of all the other cars around me but have finally finished mounting the front subframe, the n/s front wing is happily reunited with it's inner self, been trying to get some of the other morris 18 owners to take some pictures of the wing connection so I can see how it mates up to the grill and front apron as mine is all missing, might as well talk to myself can get pics from the net but not the ones that I want, so might have to wing it it'll be alright on the night... lol..... I must admit the sterling was going to be the last to sell but needs and a buyer must... lol
home of the "Mad Maestro"
Post by scoobyh123 » Mon Dec 02, 2019 9:29 pm
Progress is progress thogh Rick, as long as you're getting there. My mistake, thought ti was an 806, same car, just newer for the 807.
I suppose in the great scheme of things the exact order of sale isn't too important as long as it all happens.
thamestyres
Post by thamestyres » Sun Dec 08, 2019 3:48 pm
have now taken a slight chance and ordered the thrust bearing should arrive on Tuesday will then get it fitted, and hopefully will go to pol in it, with an eye to selling it..
Post by scoobyh123 » Sun Dec 08, 2019 10:44 pm
Fingers crossed for you Ricky! :wink: :D
thamestyres
Post by thamestyres » Wed Mar 11, 2020 8:07 pm
so its in the garage stripped and confirmed it is the thrust bearing is very noisy and not seized, is mostly back together and will be sorted for the mot while its here.. if all goes well it will be at pol in april… regards ricky
Post by scoobyh123 » Thu Mar 12, 2020 12:51 am
Fingers crossed on that one! :wink: :D
thamestyres
Post by thamestyres » Sun May 10, 2020 6:51 pm
well I was wrong although the thrust bearing was very noisy it did not cure the issue, the lesson: when you have taken the gearbox off always check the clutch properly... the issue was the spline teeth in the centre of the clutch plate had stripped on one of the plates.. the cause of this was one of the dowels were missing in the bellhousing.. it now has 12 months mot and is parked at my mums until the lockdown is over, then I will decide whether to do some bodywork or not.. but is now mobile just needs a few minor issues doing to make it reliable again.. and well in need of a good valet.. regards ricky
Post by scoobyh123 » Sun May 10, 2020 11:41 pm
Don't you just love sneaky faults Rick? Glad you got it sorted and it's mobile again though! :wink: :D
Users browsing this forum: No registered users and 14 guests
