Quick wheels question
- Location: Letchworth Garden City [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Will the wheels off a rover 25 have the same stud pattern as my 825 ?
I fancy a change of wheels.......I have seen some after market jobbies which fit the 25.
Does anyone know the stud dimension, ofset and ...........errrr.........the other bits so I can check them please .
2002 Trophy Blue Ztt 190
2004 S-Type Sport
2004 S-Type Sport
Re: Quick wheels question
No - but wheels from a 600 and some Hondas (eg Accord) will. Maestro vans and Daewoo Matiz, too.
Rover 25 fitting: 4x100
http://www.wheelfitment.co.uk/?themake= ... hemodel=25
Rover 800 fitting: 4x114.3
http://www.wheelfitment.co.uk/?themake= ... emodel=800 + Rover 600
Thank you squire...........much appreciated.
2004 S-Type Sport
2004 S-Type Sport
Is the .3 on the 114.3 an absolute ? or will just 114 do ?
2004 S-Type Sport
2004 S-Type Sport
- traineefarmer
It's a metric equivalent of 4.5 inches.
so the .3 is looseable. Cheers.
2004 S-Type Sport
2004 S-Type Sport
I can't promise that ignoring the 0.3mm would be OK, but I do know that lots of people have ignored a similar dimension and fitted BMW wheels on Jaguars
- traineefarmer
0.3mm is probably close to the manufacturing tolerance of the wheels, and definitely won't exceed the clearance of the bolt holes. It'll be fine.
I've just been down this route myself to finding alternative wheels due to a nasty ding in one rim on my Sterling and dings in one or two wheels on my coupe.
The following have the same stud pattern (114.3 x 4) :
Volvo S/V40 (1998-2002)
Mitsubishi (most models)
Nissan (most models)
Kia (some models)
Honda - Accord and Legend 4 stud (late 80's to about 1998)
I found this site helpful for stud patterns, offset and centre bore and it has a feature to sort wheels into "Fitment" groups :
http://www.carlsalter.com/all-wheel-fitments.html
One thing you need to be careful of is the centre bore which is 64mm on the 800. If you fit wheels with a larger centre (eg 67mm) you will need a set of these :
http://www.ebay.co.uk/itm/161618760689? ... EBIDX%3AIT
They keep the wheel central on the hub, prevent it being off-centre due to the wheel nuts pulling it away from the centre and support the weight of the wheel on the hub, rather than relying on the wheel nuts which are only there to hold the wheel on. I used the above link as an example of what to look for, you will need to check your centre bore and find the right size spigot rings to suit.
I've gone for Volvo BBS Crater wheels which are similar to the "Hairpin" wheels fitted to the 75/ZT models but have 8 "hairpins" instead of the 7 on the 75/ZT.
They need a bit of refurbishment but most wheels of this age will and at least i haven't paid for tyres that are the wrong size!
One last point - wheelnuts!!! The 800 uses M12 x 1.5 threads, you will need to make sure the wheel nuts you have are either suitable for the wheels you're fitting or have the same thread if you use the whee nuts from the donor car. This, coupled with the offset and size of the wheel is why i went for the Volvo wheels as i can use the same wheel nuts and the only "extra" i need are the spigot rings.
Hope that's all helpful for you!
Kia (some models)
My brain hurts now !!!! I do have a style in mind.....but until its either a go or a no go......Im keeping shtum !!!
First and foremost.......major service and belt change..........somewhere local hopefully !
My two new screens are in so I am now water tight again!
2004 S-Type Sport
2004 S-Type Sport
Users browsing this forum: No registered users and 29 guests
