OBD2 Reader.
OBD2 Reader.
Can anyone who understands these things give a recommendation for a good OBD2 reader, please. I am taking on a 2000 year car from 1st February which is OBD2 compliant. Preferably the cheapest one that still does the job.
1992 820SI saloon.
Re: OBD2 Reader.
The one I have is just a cheap ebay job. About £15 I think, it scans most cars of that era and will reset management codes.
Looks exactly like this one, though it seems to say for 2001 only.
http://www.ebay.co.uk/itm/VAUXHALL-OBD- ... SwfcVUKY7a
You can get ones with a lot more info on them but haven't used one myself. On mine it gives you the code and nothing else. You then have to google the code to find out it's meaning.
A trivial thing but be aware you can't reset the service light on a V70 by one of these. Only the dealer type setups can do it. Forget the name of it now. It goes off after about 2 minutes anyway if it's showing. Any that I had with it on I just ignored it.
Re: OBD2 Reader.
This is another option that you can (i believe) leave connected while driving. It sends the data via Bluetooth to your smartphone and there are a variety of apps (some with listings of the DTCs) to use with it so you can see what's happening as you drive - useful if you have an intermittent fault and need to know what's happening as/just before the fault occurs.
http://www.ebay.co.uk/itm/Mini-ELM327-O ... SwHQ9WXDhH
Both systems have their merits, your choice at the end of the day.
I think the 2001 thing is when cars must comply with OBD II although many were OBD II compliant before that.
