OK, I'll admit it's not very impressive!
When we had our Hi-lux Surf a few years back I used to be quite into green laning, but at the moment it's hard to find time to breathe let along go off into the countyside in the Jeep however we have this little track near to us so I thought I'd give it a quick go. Sadly the weather's very dry at the moment so no mud to play in, will go back after some rain!
Happy to say the Jeeps running well though, very smooth and quiet, bit rolly polly compared to the ZT but that's to be expected. Haven't yet filled it with gas however the trip computers showing just over 20mpg which in cost terms means it's getting the equivalent of 40mpg......not bad for a 4.7 V8
Finally got offroad..........
Guru - AKA James
m6jkk.com
Current Fleet
2015 Mercedes C300 Hybrid
2015 Mini Cooper SD
m6jkk.com
Current Fleet
2015 Mini Cooper SD
- Location: Plymouth, Devon [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Finally got offroad..........
Are you going to stick the winch on the front etc to go in greenlaning?
i want lots of british cars got 1 want more
Further than most 4x4 owners get!guru wrote:OK, I'll admit it's not very impressive!
Nah, I'm not brave enough to go anywhere that i'm likely to get stuck in!Thomas J wrote:Are you going to stick the winch on the front etc to go in greenlaning?
Guru - AKA James
m6jkk.com
Current Fleet
2015 Mini Cooper SD
m6jkk.com
Current Fleet
2015 Mini Cooper SD
