Rover 800 Banner
Moderators: TDHFastback, guru
- TDHFastback
- Moderator
Rover 800 Banner
I have sorted out a banner for use at shows with a local firm where I live.
This one is 1.2m X 1.2M but could be smaller if required.
The cost was £45 and there are 4 eyelets on each corner though you could have more if required.
I have used the same design as the sticker for a bit of corporate identity but if you wanted different colours I could sort something out.
It seems to be made of hard wearing rubber like material and seems quite durable but only time will tell.
If you would like one please PM me.
Thank you
Kate
Thank you
Kate
- TDHFastback
- Moderator
- TDHFastback
- Moderator
- metelmickey
- Location: hampshire [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
- Richard C
- Location: Gloucestershire [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Comedy GoldTDHFastback wrote:Your response confused me for a bit then I re read my message
I can see its going to be one of those days. Really Brian. The banner, I meant the banner
men
Kate
Richard
@Rich_Clements
@Rich_Clements
- Joined: Thu Mar 28, 2013 8:52 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Rover 800 Banner
Is this banner still available.
I am a new member of the forum - living in Denmark - and I have just purchased a bargain of a 820 Si automatic ´95 at appr. £700. And bought directly from the first owner !
It has taken me about 38 years to achieve this, as it is that long ago I first fell in love with a 3500 saloon. A lot of water has since then passed under the bridge - among others a visit to the factory in ´89 and a joboffer from Rover in about ´94 (few weeks before the dismissed 3-4000 employes) - so now Im finally here. Owning a Rover.
It is my plan to drive in this the comming month as it is due for MOT in december. I will during this period check the car from top to bottom to see if it is worth (bad word, actually) renovating. If not I will proceed to my next goal - a 216 or 220 GTi (´91-´95). I know for sure it will need a lot of work (or new parts) platewise around sills and doors. But as this car is a beauty, and a pleasure to drive, it would be a shame to let it go to breakers.
But back to my original question. I am interested in this banner for my workshop if it is still available.
Happy easter greetings from Denmark
Kaare
Kaare
- TDHFastback
- Moderator
Users browsing this forum: No registered users and 0 guests
