Hello :)
- FlashGordon
- Location: Galliae Cisalpinae, oram fluminis septentrionalem Rubiconem. [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hello :)
Im from italy, Rover 825 SD with 700.000 Km owner, sorry for my not perfect english
Flash
Flash
Flash
- Location: Plymouth, Devon [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Hello :)
Welcome 700,000 km or 70,000 if its 700,000 well done
i want lots of british cars got 1 want more
- FlashGordon
Re: Hello :)
That's 700km, accurate to the nearest metre.
Welcome aboard Flash!
GORDON'S ALIIIIIVE!
GORDON'S ALIIIIIVE!
Re: Hello :)
Welcome to the flagship forum for all things 800
Re: Hello :)
Gordon's alive! Welcome aboard Flash, good to hear from Italy and the home of the VM engine!
Don't worry, your English is much better than my Italiano!
- FlashGordon
Re: Hello :)
Thank You Guys, yes Gordon's Alive, Im from Rimini, same region of where VM engine is product
Flash
- FlashGordon
- FlashGordon
Re: Hello :)
Flash
- FlashGordon
Re: Hello :)
Adventure with proportional valve, must go buy special tool for security bolts, who had idea to use security bolts in a valve of Rover 800? Anywhay after i used normal bolts. I used old o-ring and red liquid gasket for hight temp (for water pump) maybe is not right but i had only it ))) Inside was cleaned, no rusty, stop leak but no time for take out air inside line.... but car brake with air inside line too , miracle 800 )))
Flash
- FlashGordon
Re: Hello :)
Flash
- FlashGordon
Re: Hello :)
Flash
Re: Hello :)
Some very good work there, Flash.
It's great to see some proper hard work going into keeping the 800 going in foreign lands. How is it finding spares in Italy?
Re: Hello :)
At least he won't have a problem finding engine spares Tom!
Like the idea of cameras front and rear with the screen built into the sun visor! Don't know if you can get these in Italy but we can get rear-view mirrors that change to monitor screens when the camera is active :
http://www.in-car-stuff.com/shop/clip-o ... p-259.html
Same people do another version that can show 4 cameras at the same time but it's expensive.
FlashGordon wrote:Thank You Guys, yes Gordon's Alive, Im from Rimini, same region of where VM engine is product
