Hello :)
- FlashGordon
- Location: Galliae Cisalpinae, oram fluminis septentrionalem Rubiconem. [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Hello :)
In Italy official shops of spares Rover close several years ago but was also very expensive, for example a water pump for 825 SD 300 euro in shop, last pump buyed trough internet about 30 euro plus shipping, now I find spares with ebay and Rimming Bros http://www.rimmerbros.co.uk/Item--i-GRID004769 here synchronizer for my gearbox for example
Flash
- FlashGordon
Re: Hello :)
I buy cameras and monitor with ebay from china, must wait one month for shipping but super chiperscoobyh123 wrote:At least he won't have a problem finding engine spares Tom!![]()
FlashGordon wrote:Thank You Guys, yes Gordon's Alive, Im from Rimini, same region of where VM engine is product![]()
Like the idea of cameras front and rear with the screen built into the sun visor! Don't know if you can get these in Italy but we can get rear-view mirrors that change to monitor screens when the camera is active :
http://www.in-car-stuff.com/shop/clip-o ... p-259.html
Same people do another version that can show 4 cameras at the same time but it's expensive.
Flash
Re: Hello :)
Welcome!
That is an impressive millage
. Well done.
My 800 has only done 1/7th of your car
Great colour you have by the way!
- FlashGordon
Re: Hello :)
Yes, millage for go on the moon and back
Colour is not original Rover, black metalized from Alfa Romeo, special transparent with ultra slow catalyzer for have ultra lucid
Flash
Re: Hello :)
Seems there are 2 different water pumps fitted on yours, a 71mm impeller and a 76mm impeller. Not sure how these compare on price but pretty cheap here as water pumps go :
http://www.eurocarparts.com/ecp/c/Rover ... 67c&000366
76mm
http://www.eurocarparts.com/ecp/c/Rover ... f7b&000366
71mm
I'm not too well up on the diesel versions but i know on the petrol engined cars a lot of parts can be sourced from other cars, for example the Lambda/oxygen sensor on the 827 is the same as many Vauxhall/Opel, Daewoo, Suzuki Swift and many other models. I do know the VM engine also went into the Alfa 156 and Jeep Cherokee as well.
Don't know if those water pumps would work out any cheaper for you with the exchange rate and shipping to Italy but may be useful to know you can get parts from other places too.
76mm
71mm
Re: Hello :)
It's a VM. He'll never need any spares for the engine. As for the gearbox, bodywork, interior trim, electrics, etc....scoobyh123 wrote:At least he won't have a problem finding engine spares Tom!![]()
- FlashGordon
Re: Hello :)
Yes, it fit 71mm or 76mm without problems, of course with 71mm flow of water is less, good for cold lands, not for Italy.scoobyh123 wrote:Seems there are 2 different water pumps fitted on yours, a 71mm impeller and a 76mm impeller. Not sure how these compare on price but pretty cheap here as water pumps go :
76mm
71mm
My VM engine is from 1992, first with EGR and transmission by gear, no chain, from 1994 VM begin use chain and after 100.000 Km tensioner of chain fail and then destroy engine..... my engine with gears is not possible destroy.... Alfa 156 and 164 too used VM, when i need gasket for cilinders i go buy to Alfa garage
A lot of car brands used that 2,5 VM engine, london taxy too
Engine is a bit increased with CV, more pressure in Turbine and injectors pump rebuilt, response of injectors pump is more fast with poor pressure in turbo too, match with Jaguar 2000 petrol, my 825 diesel win, about 210 220 Km for hour on the road
Flash
- FlashGordon
Re: Hello :)
Errata corrige that link 76mm is for MK2 and 71mmm for MK1 in this case, even for VM
Flash
- FlashGordon
Re: Hello :)
Electric plant in my 800 is more bad of Greek tragedyl, lot of original plant bypassed and build new with new thingstraineefarmer wrote:It's a VM. He'll never need any spares for the engine. As for the gearbox, bodywork, interior trim, electrics, etc....scoobyh123 wrote:At least he won't have a problem finding engine spares Tom!![]()
https://www.facebook.com/marco.brunacci ... 296940221/ https://www.facebook.com/marco.brunacci ... 296940221/
Flash
Re: Hello :)
Welcome Gordon, 700,000km
that's got to be a record for any Rover 800. Cars in UK have usually dissolved before they get anywhere near that.
Mk2 Vitesse Fastback
Re: Hello :)
Excellent work! My first 800 was a Mk2 diesel which, when I collected it had over 330k miles on the clock - that's over 530000 km, so still a way short of yours.
- FlashGordon
Re: Hello :)
Thank you, my friends make betting about how many time my old car will survive again lol
Flash
