tonewheeldude
Post by tonewheeldude » Thu Nov 12, 2015 6:19 pm
After Repair:
ImageWP_20151112_14_07_15_Pro by T_W_D, on Flickr
repaired area nearest bottom of photo
And tracking - suprisingly not agreat dealout, just tweeking on the front and rear N/S:
ImageWP_20151112_15_29_17_Pro by T_W_D, on Flickr
deano
Post by deano » Thu Nov 12, 2015 6:30 pm
is that a rover badge hanging down underneath the rear bumper ?
tonewheeldude
Post by tonewheeldude » Thu Nov 12, 2015 10:09 pm
I have to tow a trailer sometimes, and not wanting to spoil the look of the coupe searched for a genuine towbar kit, I was fortunate enough to find one last year and a few weeks ago came across a brand new set of Rover electrics (so no cutting into the wiring). The 13pin trailer plug has a Rover badge on it and to protect it I bought a rubber cover and put a Rover badge on that too - which is what you are seeing. The tow hook is removeable and not on the car in the photo.
Post by scoobyh123 » Sun Nov 15, 2015 3:40 pm
Oops! Painful! If that doesn't cure the wheels, there's a KV6 saloon with some nice 15" alloys being broken :
viewtopic.php?f=15&t=13547&p=136361#p136361
tonewheeldude
Post by tonewheeldude » Mon Nov 16, 2015 4:15 pm
Thanks Dave, I went to the NEC in it this weekend and it all seems fine now. That V reg saloon looks too nice to break.
Post by scoobyh123 » Mon Nov 16, 2015 5:27 pm
It does but it was up for sale on here for ages and then ebay at least once.
Glad you got the wheel sorted out and the tracking etc and no other damage!
FlashGordon
Location: Galliae Cisalpinae, oram fluminis septentrionalem Rubiconem.
Post by FlashGordon » Thu Dec 10, 2015 1:10 pm
tonewheeldude wrote:
scoobyh123 wrote:Slave cylinder repair kit on fleabay :
http://www.ebay.co.uk/itm/Reparatursatz ... 5424d4e01b
For reference the OE part number is CDU2331EVA and the listing has a few more OE numbers as it turns out to be the same seal kit used in some Marinas, Saabs and Allegros. They also list a new cylinder for about £35 + P&P but they list it for many other 800s including petrol and the 820/620 turbo. The turbo versions may be another possibility but as i expect you've found, the diesel uses a unique slave cylinder.
http://www.ebay.co.uk/itm/Kupplungsnehm ... 5d5d7c923c
I started out by looking for Jeep Cherokee 2.5TD and Alfa 156 TD slave cylinders as both of them use the same VM engine. However not much seemed to correlate.
Not sure if any of that is any help or whether you've already been down that route of looking for alternative vehicles.
Hi Dave - thanks, although these are slave cylinders and seal kits for a standard petrol 800 - the slave cylinder is completely different on the diesel:
and the seal (17mm) is the wrong size for my car which is 19mm.
mercedade wrote:That's a great result - congratulations! Must have been a massive relief too.
Absolutely! As much as getting to know new folk is great - I was not relishing the idea of spending most of the day in a truck with a recovery chap, plus it made it easier getting my wifes family home too.
Found some rubbers similar at last?
Must rebuild clutch slave cylinder in my 825 diesel but very hard find seals
This one maybe? :
http://www.ebay.co.uk/itm/DISCOVERY-1-R ... 1119067665
Flash
Post by scoobyh123 » Thu Dec 10, 2015 2:10 pm
I think after Darrens recent experience with clutch slave cylinders he's now the "go to" expert on them so i'll let him answer that one! :wink: :D
tonewheeldude
Post by tonewheeldude » Thu Dec 10, 2015 7:57 pm
Thanks Dave - not by choice I assure you!
the 514244 lockhead kit fits a number of vehicles and cross references to lots of other manufacturers, but I couldn't seem to find the diameter (although it might be 22.2mm) - the 825 dieselseal needs to be 19mm. There must be another slave cylinder with the same bore...thats what we are looking for. - I will keep on the look out too.
My seals came out of a Land Rover wheel cylinder I think.
FlashGordon
Post by FlashGordon » Mon Dec 21, 2015 6:33 pm
Someone try if seal of this kit fit?
http://www.ebay.co.uk/itm/ERT-300563-RE ... SwHQ9WXU9R
There is write:
Additional details of the part:
Diameter [mm] 19, Brake System BENDIX-BOSCH
Flash
tonewheeldude
Post by tonewheeldude » Tue Dec 22, 2015 12:27 am
FlashGordon wrote:Someone try if seal of this kit fit?
There is write:
its not expensive so I guess worth a try?
Post by scoobyh123 » Tue Dec 22, 2015 12:53 am
There is write:
Go on - you know you want to! Have you got a dead slave cylinder or two that you could give it a try on? If it works then you can keep it in the boot as a spare in case the new one lets you down instead of having to wait a few days for recovery of you, the car and your passengers again.
FlashGordon
Post by FlashGordon » Sun Dec 27, 2015 6:02 am
Flash
FlashGordon
Post by FlashGordon » Mon Dec 28, 2015 12:24 pm
Original seal is 19 x 12 x 5 mm,
will try this 19,2 x 11,2 x 5 mm ... maybe it fit
Flash
tonewheeldude
Post by tonewheeldude » Sat Jan 09, 2016 4:38 pm
grrr, the Front pipe flexi is blowing. Was new last April!
Users browsing this forum: Google [Bot] and 28 guests
