dads mgf
- metelmickey
- Location: hampshire [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
dads mgf
hi, my dads having a mid-life crisis ( he's only 75 ) and bought a P-reg mgf, nice little car but does not like to run when cold, fine when warm and will run with a little throttle been told it has the sensors replaced ie: crank,cam etc but has made no differance, is there a wax stat like the vw have or is there anything else i can check, many thanks.
MIKE
just got a 827 mk2 coupe and loving it, more commanly known as mad mick ( used to run a nitros injected firebird ) still missing my rover, now got a BMW 735 1999. now got 2003 760l, a 6.0ltr V12 and 445bhp.
- Location: glos [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: dads mgf
idle control air by-pass valve, screwed to the inlet manifold just behind the throttle body. Its just an electronic controlled plunger but they can become blocked.
Re: dads mgf
Also check the CTS, i've known them give similar trouble on the K-Series.
- metelmickey
Re: dads mgf
many thanks will give him the info so he can have a look
MIKE
Re: dads mgf
Something else i've just thought of Mike, could be worth doing a compression check as well. Just before the dreaded HGF attacked my friends ZT turbo that started running rough when cold, could also be worth whipping the plugs out when it's been sat overnight to see if there's any dampness on any of them.
- thamestyres
Re: dads mgf
an ecu reset sometimes works.. it forces it to relearn sooner rather later, with sensors replaced it may be trying to relearn everything... regards ricky
Rover Sterling KV6 V.reg 4 tailpipes and rs5 wheels (sold)
home of the "Mad Maestro"
- metelmickey
Re: dads mgf
sorry to inform every one but dad died on wednesday, so the mgf is being sold, he did a lot of work on it and enjoyed it all ( replaced the suspention tops, gear linkage, etc ) will be going to a man who loves them and has a few.
MIKE
Re: dads mgf
Really sorry to hear that Mike, glad you've found a good home for the MG-f, hope you're looking after yourself ok as well.
- SJG
Re: dads mgf
Sorry to hear this sad news Mike, take care of you and yours.
- rovercoup
Re: dads mgf
Glad your Dad enjoyed the time with you working on his MGF and his pride and enjoy will be looked after.
Condolences to you and your family Mike our prayers for you at this sad time.
Re: dads mgf
As above, sorry to hear that.
Not a nice time, been there unfortunately.
Re: dads mgf
So sorry to hear the news, Mike. I'm glad that it will be going to a good home and that your dad's efforts will be appreciated and built upon
- thamestyres
Re: dads mgf
as above mike my condolences.. regards ricky
