ABS sensors
- Location: Cambridge [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
ABS sensors
Does anyone know where to get ABS sensors from..?
Richard
1997 820 coupe
1999 820 coupe
1994 Montego Countryman 2.0i
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
Re: ABS sensors
Front or back ones Dick?
http://www.ebay.co.uk/itm/371033272993? ... EBIDX%3AIT
Those are the front ones, something odd about the left/right thing on them so you'd need to speak to Ron at Best of British (the seller) but also if you phone up rather than buying over ebay, you can probably negotiate a discount for buying a pair.
I had to drill, burn and grind the old ones out of the brackets on mine, i then sanded the hole a smidge oversize and mirror polished it and packed Vaseline round the outside of the sensor to prevent further corrosion of the bracket which is the main cause of failure as the aluminium oxide crystals grow and crush it!
The back ones are the same as Volvo 7/9xx front ones or indeed Mk3 Cavalier (and possibly others) but obviously they use different plugs so you may have to cut'n'shut a plug if buying a sensor for one of those.
Re: ABS sensors
Thanks, Dave!
Richard
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
Re: ABS sensors
You're welcome Dick!
Did you get sorted?
Did you get sorted?
Re: ABS sensors
Not yet, Dave, but Ron is very helpful, and a good source of spares...are you going to the 1st April meet? And on 2nd April, there is a show at Old Warden...
Best wishes,
Dick
Best wishes,
Dick
Richard
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
Re: ABS sensors
At the British Queen you mean Dick? That's certainly the plan at the moment, hopefully in the Sterling with the other confusing set of wheels!Caxton820coupe wrote:..are you going to the 1st April meet?
Where is Old Warden? Haven't heard anything about a show there?Caxton820coupe wrote: and on 2nd April, there is a show at Old Warden...
Best wishes,
Dick
Re: ABS sensors
Yes, Shepreth, or wherever it is ...
Old Warden, the Shuttleworth Collection, near Ickwell, Beds. google it and you'll see...
Richard
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
Re: ABS sensors
That's the one!
Could only find an Easter Sunday meet online for the Shuttleworth collection/Old Warden, am i missing something obvious?
Re: ABS sensors
type in Old Warden car show, and click on the first result, and you should get the right information...
Richard
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
1997 820 coupe
1999 820 coupe
2010 Honda VFR1200F
1997 Honda VFR750F
1989 Honda CBR600F
Re: ABS sensors
The first (non-sponsored) result i got was this Dick :
http://www.shuttleworth.org/events/classicrally/
Is that the one?
I had about 6-10 results before that, all sponsored by some search engine or commercial interest!
Is that the one?
Users browsing this forum: No registered users and 59 guests
