- mjc9967
Late to the party I know but two points:
1) Fob barcodes were often kept in the owners manual wallet, if it still exists
2) My garage in St Albans has managed to get a R600 fob work in a Mk2b. (I think zeros were used as leading characters where the 600 fob code was too short?) Keep the barcodes for later...!
- Joined: Sat Aug 12, 2017 6:14 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Quoted £322 for 2 fobs (1 working), ECU and CCU. but would prefer 'Fastback's ' option. Do I remove my ECU, send off and receive back working Fob for £150 each ?? I've already tried to get a Thatcham alarm fitted , with no success.
Just to clarify, after bypassing the immobiliser etc does the car start and run?
Starts and runs ok, when Battery allows. Opening the Bonnet seems to set off the alarm. Starting her stops the alarm. Due MOT mid April, would prefer her operating properly by then.
That's what i was afraid of. Sounds like you still need to do the EKA procedure each time to disarm the alarm so you still need a fob then.
I'd better disconnect the Battery, remove ECU ready for sending off. let you know result soonest.
I think you'll need ECU, CCU and maybe something else - would pay to check on the website for everything you need to send them.
YIPPEE....sorted. sent off ECU,CCU and key. rec'd all back plus 2 x working Keyfobs. (Remote Key ltd of Bournemouth) £289 all in. next on to bodywork. Any got 4 x door trim for nightfire red 825 ?? Col
That's great news, glad you got sorted!
Are you after the door cards or the external door trims?
Just the external Door Trims. MOT Wed 11th 9.30am. then I can crack on with the exterior. I was in too much of a rush when I took the old ones off, a lot of Gorilla Glue being used at the moment. Col.
Is it the rubbing strips/body side mouldings you need then?
I'd go with 'body side mouldings'. Had offer of 4 for £40 from 'Tiffa', but don't fancy rubbing down, respraying 'Nightfire Red' and showing the rest of the bodywork up. Col.
I'd go with that before he changes his mind about selling them because they usually go with the doors as a complete thing to avoid mismatch of paint.
Not so much of a problem on a Mk2a as they had black rubbing strips. I did have a set of those but looks like i've binned them - quite possibly because the person i got them from as a job lot had removed all the fixings.
He seemed to have a thing about stripping everything to its component form - had some window regulators in the job lot, complete but the counterbalance springs that are meant to be on the regulator where the motor attaches had all been removed! So had the the motors! Whole lot rendered useless as various small parts were lost along the way, even if i could have found a way to refit the counterbalance springs!
3 Litres Auto gearbox oil replaced, Timing belt kit ordered for next months job. Is LPG worth considering ?? She's starting to look & run like a 10 year old..... Col ( ain't retirement great )….
Could do with a 'Under Bonnet - Sound Proofing Sheet', struggling to find right size available, any idea's ?
